black oily spark plugs...???
Discussion in 'The Garage' started by cheyennesuper, Jan 22, 2005.
  1. cheyennesuper
    cheyennesuper Registered Member
    Nov 2, 2004
    52
    Wisconsin
    Let me start from the beggining...My '73 blazer is getting spark and gas but it will not run.It doesn't even pop when turning over and its turnin over real good.I know its getting gas because i looked and saw plenty of gas shooting in the venturies of carb while my dad pumped the accelerater.I removed the plugs to see if they are wet and nope.I dip the number one plug in gas and it popped once on the number one cyl. when i turned it over.I thought maybe its compression so i took the rest of the plugs out to squirt a little oil in the cylinders and the plugs nearest to the firewall are all covered in what looks like used oil.Can anyone give me some advise?Thankyou...
  2. g_mo
    g_mo 1/2 ton status
    Dec 28, 2004
    131
    tx
    sounds like the plugs are fouled. if the truck has been sitting for a while, oil may have drained past the valve seals and fouled the plugs. put some new plugs in it or clean the ones you got real good and see what you get.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sounds like it needs stem seals and/or rings too
    try new plugs and see if they oil foul again, if so then time for work
    good luck
  4. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    I had a 350 in my 69 camaro that had bad rings would foul the plugs to the point it would run bad every 100 miles. A trick to clean the plugs and combustion chamber if you get it running, is to run a large cup of water through the engine while it is just above idle. Pour the water in slow enough that it doesn't stall the engine. Makes for a nice and clean engine if you have to tear it down for inspection. Steam cleaned. I used do the water trick every other day until I had the money to get the engine rebuilt. Your fouled plugs made me think about it. The fact that it is only the plugs toward the firewall make me think it is your valve guides. You might be able to do a cheap fix by installing umbrella type seals on them.
    Also, if you are worried about putting water in your engine, I understand that tranny fluid works just as well. I wouldn't use tranny fluid if you have catalytic converters.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    screw all that other crap! do a compression test and/or a leakdown test. that will tell you exactly what's up, the rest of the stuff mentioned is just a bandaid fix for a bad situation.
  6. clstolten
    Sep 4, 2002
    356
    Sometimes a bandaid fix is just what you need until you have the time or money to fix it properly. The water trick will remove carbon buildup from the valves and improve the valve seal. But yes, definently do a compression, and leakdown test.
  7. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    clean the oil returns
    The oil return holes in the head might be plugged up with sludge,and not allow the oil to drain back down into the block,this will aggravate any valve seal problems,since the valve stems wil be swmming in a puddle of oil,even good seals will suck oil past them if they are submerged in a puddle of oil--the fact that mostly the rear plugs are fouling tends to point to clogged drain holes in the heads,cause the motor is lower in the back than the front,and the return holes nearest the firewall are usually the ones that clog first..pull the vale covers and have a peek--if its nice and clean,with no sludge--better start saving for a rebuild--non foulers on the affected plugs will get you by for awhile...:crazy:
  8. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,006
    609
    Pueblo, CO
    I you are running an automatic trans and the only the back to plugs are fouled on the passenger side, it can be something other than valve seals. I had a ruptured vaccum modulator on a TH350 in my nova and it fouled the back to plugs on the passenger side in a very short time. Saw it smoking at night when looking back throught the rear view mirror. Thought I broke some rings it smoked so bad. further inspection revealed that while the plugs were oil fouled, they were white in color (big tipoff for burning ATF). Just so happens that the vaccum line for the Trans was in the port that fed the back to cylinders on that side. The leaky modulator allowed the engine to suck the ATF out like a fat kid sucking down a chocolate shake through a straw. (in other words FAST!).
    Sounds like they were oil fouled to me. Valve stems worn/seals brittle or poor ring seal. Do the compression test and leakdown test like it was said for a better diagnosis of the problem.
  9. gmchevy
    gmchevy Registered Member
    Apr 14, 2004
    28
    North Carolina & Colorado
    i had the same problem with a 79 that i owned, turned out that the last two lobes on the cam were flat. major carbon build up
