Black Primer pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, Jun 12, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    A little sanding (actually alot) and some black primer goes a long way. Check-out my before and after pics. One day when I get sick of the primer i may paint my truck, but until then I'll just keepa sandin' away!
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Looks way better
    I also am transforming my rig to primer then to a color.
    This weekend I started with the inside bed area and man my arms hurt today.....[​IMG] but it's lookin better with every step!
    Late
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    Vast improvement!! I'm thinking about doing the same to my '78. One question - what about the top? Can I just have at it with a Wagner power painter, or is there some prep work involved (aside from scraping off the crud)?
    behemoth K5
  4. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    No offense to you primer dudes but I was told by a few body shops that primer is actually bad to have on the vehicle over time. Primer has clay which holds moisture causing rust and does not give a protective barrier like paint does. I was told if I want the primer look to get flat gray, black or red paint. Back when I had my 70 Chevy truck, I sanded the paint down to bare metal and primered it. After a month or two, I did notice rust starting to appear all over. To paint it (6 months later), I had to again sand down to the bare metal and re-apply the primer.
    Shawn
    87 K5
  5. Burt4x4
    6,854
    Hmm, good advise i think after I primer the tub I will put a coat of flat black on it to giv it the seal out moister deal!!
    Thanks[​IMG]
  6. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I used to have my Blazer primered black and it is true about it letting the moisture in and allowing the truck to rust. Also, I left my truck in outdoor storage for almost a year. When I got back and took a look at it, it had turned grey! It turns out that black primer doesn't like to stay black. Now I'm using Flat Black paint and I love it. It seals out the moisture and stays the same color. Just remember, different brands of black will have a slightly different tint to them, so you'll want to try to stick to just one brand.
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    You can put sealer over the primer and it won't rust and you retain the primer look, alot of hot rod guys do this.
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    DMK is right, hot rodders have been doing it for ages. As long as you put a sealer on it , you shouldn't have any problems. I wish I had a dollar for every lead sled I've seen with just primer.....I'd be rich !
    L8r,
    .Riz.
  9. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    What kind of sealer would y'all recommend? And what kind of primer for that matter? Thanks.
    Chris S.
    '85 & '78
