Black smoke out of new Crate motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Jun 12, 2000.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I noticed the other day that I had black smoke coming out my exhaust. My motor is a brand new crate 350, with just about 1000 miles. I remember this topic being brought up before but didn't pay much attention to it. Anyways, why is this, and what does black smoke represent? As always, thanks.
    Boss
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Not positive on this but it sounds like it may be running too rich. See if you can have some lean your carb a little. What carb on you running anyways?
    Shawn
    87 K5
  3. Boss
    2,550
    Maryland
    Shawn,
    I'm running a rebuilt Rochester Quad Carb.
    Boss
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I'm thinking it may be your air/fuel mixture.
    readjust and see if that helps....
    if not get a piece of cardboard and place it in frnt of you exahust tips and see if oil is spitin out, if it is get a new motor your rings didn't seat properly and your warrinty should cover that, I think!?
    Good Luck!
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  5. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Maybe you outta have a look at your plugs because the evidence will be more straight-forward. If they're black and sooty, it's too rich. If they're oily, start thinking about returning the motor.
    good luck
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Black smoke = too much fuel.
    White smoke = oil.
    It's running too rich. Have the carb tuned for that particular engine and it should run like a champ. If the engine has a hot cam, it can cause the power circuit to come in too early. The lower vacuum the cam creates will fool the stock power valve into thinking the throttle is open further than it really is. The power valves are available with different vacuum ratings to correct for this.
    http://ThunderTruck.ColoradoK5.com
