Blast Media
Discussion in 'The Garage' started by chiefheaphy, May 2, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Gonna blast my frame and other parts Sat. with a rental. Any recommendations for media type? Can I just use cheapo sandbox sand from Home D or Lowes? Er do I have to get Black Beauty? Im not building a show truck here, but do want to do it right.
    Tape the surfaces I dont want getting blasted?
    self etching primer right after?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For frame I would just use the cheapest media I could find. If you dont care about reusing it.
    Aluiminum oxide media works better and faster but costs more reuseable.
    Black diamond is fairly cheap works better than sand with no silica dust reusable.
    If you use sand be sure to use a resperator or at least a dust mask and a hood.. It produces silica dust which can screw up your lungs. I dont know if the non silica playground sand at HD will be coarse enough to do the work you want quickly.
    You need a medium grit 20/40 sand to clean frames.
    And yes and yes to your other questions
  3. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Thnks
    HUge Help. I have the blaster for 24 hrs and I dont mind a little labor. Frame aint horrible, I think I'll try to get away with the sandbox sand.
  4. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    I wouldn't recommend the sandbox sand. it will pack up in the blasting equipment, and it isn't very coarse. play sand just bounces off stuff.
    you need to buy actual sandblasting sand that has the ability to shear off the rust & scale.
    How big of a compressor you got? little ones are a waste of time too.
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah thats what I thought. I have never used it or heard about using it. But I looked at it one time because It had no silica but I thought it was too fine and soft to do any good.
    I usually use Black diamond for steel.
    Glass bead for aluminium/soft metal.
    But for a one time thing with a rental just use sandblasting sand. it is harder and made for the job you are doing. Playground sand is made for kids. Sand blasting is a slow process. Put a tarp down to collect the sand. That way you can reuse and mix it with unused sand if you start running out.
    Be sure to use a resperator. A hood is better than a face sheild . Face sheilds get dusty real quick and you cant see poop. Do the job outside if possible. If not make sure you are well ventlated.
  6. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Eff sand box sand.
    I jst thought it would be easier to get. The rental place doesnt carry blast media.
  7. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    How big of a compressor you got? little ones are a waste of time too.[/quote]
    diesel tow behind
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    if your going thru the hassle to blast it, zinc chromate it...
  9. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    I would
    Ive been callin all around lookin for the stuff, but nobody at paint or autobody stores has any idea what im talking about.
    I think rustoleum 7400 series is what im looking for. My local Ace could order it with a part #.
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Well, if an autobody supply place doesn't know what zinc chromate is, they're smoking crack while sniffing their paint...
    The most common, and best self etching primer for decades... he!!, you could do a frame with about 3 rattle cans of it... just need a piss coat...
  11. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Nice
    Not much room for error with that can.
    Any idea where you can pick up sandblast media?
  12. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    You can get the sand in bags from a local concrete/construction supply company. Or from a local sandblasting company. Look in the yellow pages under sandblasting. Many commercial paint supply stores also carry it.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    any place that sells aggregate should sell it bagged... We use to have good luck with 00 course sand when we did mixers, dumps, etc...
    also, keep in mind you'll stil want to put a standard primer over the zinc.. preferably an epoxy...
  14. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Lbs.
    What is a safe amount of media to purchase? Planning on doing the Frame, 2 axles and some other small brackets and x-members?
  15. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Definitely DEFINITELY get real media and get something coarse. Blasting gets real old real quick, especially staring at the same square inch of metal waiting, waiting...
    That said, if you are renting, check out the gun and tip or tips that they provide as some grits will not work well.
    And as said, use a hood, that sand gets everywhere, and when it's hot it sucks getting it down your shirt right into your crack. :D
  16. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I've used sandbox "play sand" with great results, but it wasn't on a frame. It's possible that my results are non-typical, but it worked great on old rusty and painted parts. Also worked great on new metal before painting.
    I just catch everything in a cheap kids plastic swimming pool, and then reuse it several times. I didn't get any clogging at all, and mine isn't anything close to a pro set up. I have a craftsman cheapy blaster.
    But for a tough job, (or if i was doing a frame) I would at the very least get something intended for blasting with.
  17. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I used Play Sand from Lowes when I blasted my Hummer rims. The paint they use is very tough. It took about 4 bags per rim. I would have liked to use Black Diamond or Star Bright but the driveway needed the sand. I am thinking of building a blast box so I can use better (high dollar) grit.
  18. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Black beauty
    I got 800lbs at 15 bux a 100lb bag today. Better to have more than enough than not enough.
  19. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    We always use Black Beauty on our tug boats at work (I actually loaded 2000 lbs. of it in our work truck today, haha). I think it might be more for regulatory reasons but I've also heard it does a really good job.
    -Wes
