Blazer 350 on propane?
Discussion in 'The Garage' started by Disciples Performance, May 28, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    Hey guys so im selling my first K5 cause its just a lost cause no point in me dumping my time and effort into that one when i just found a way better one for 900$ and jsut needs doors and 1 rocker i already have the doors and 3/4 ton axles for it with 33's and 4 inch lift kit so it has a 350 on propane does anybody like running propane engines in the bush how are they for power ive always had gas so i dunno what propane is like but i like the fact that i can get it for like 60cents a litre CAD :D so just let me know what you all think about it
    Nick
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    range may not be great, wherever you go you have to find a place that will fill it up. But how it runs? great, though less powerful. The exact same motor and settings on Propane vs Gasoline the gas will make more power than the propane. Now Propane has higher compression, so throw on some new heads for lower compression, and advance the timing and that engine will come alive. I am putting propane on my project S10. 383 with around 11:1 compression and a roller cam. Ought to run well on the LPG. If the parts are in good shape Propane rocks. Oh and propane runs at any angle. No fuel pickup or pump so starving for fuel only happens if a component fails or you run out of fuel. Of course, when you run out of fuel, you can't grab your red can and go over to the local gas station...
    Pros:
    -any angle running
    -cheap
    -higher octane
    Cons:
    -mileage is slightly less from what I'm told
    -less power on the exact same engine
    -can't just top it off with a red gas can
    -finding fueling stations
  3. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    I run it and love it its cheap and simple you just need to think ahead and find a place to get it from all the time you can always carry a forklift tank around as a spare also.
  4. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    ya i was thinking a BBQ tank even but how do u find it for power?? lots of balls or not so much?
  5. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    From a previous post, might be applicable.....
  6. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    they big thing is to have a motor with mods that is ready for it then it will beat the crap out of a normal 350
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Police cruisers have them, they need some sort of power to pursue the bad little children out there on the highways..:dunno: :D :p:
  8. Quicksilverb33
    Quicksilverb33 Registered Member
    May 28, 2006
    8
    Wake Forest,NC
    do u have any pic of it ?
