blazer body on truck frame
Discussion in 'The Garage' started by big dan, Sep 11, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ive found lots of threads on putting a truck cab on a blazer frame but not a blazer body on a truck frame. Ive got an 84 pickup that Ive shortened to a 110" wheelbase and I recently found a 73 complete body with very little damage and no rust that I can get real cheap and would like to put the body on my frame. from what I can tell the only mods I will have to make is to move the rear cab mounts to the outside of the frame. I know the frames are a little different at the back so will there be any other problems or will it just be the body mounts? thanks
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you are going to end up with several different height body lift blocks to make it work. what is wrong with the blazer frame? why not swap running gear instead. bodies are heavy an awkward. I swapped a regular cab with a boom truck and would have avoided it if I could have. If you do it post pics.
  3. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    the blazer doesnt have a frame, its just a body sitting in a guys yard. do you know what size and how many blocks I need? I know its a lot to ask but it would be easier to have the blocks ready then have to make them on the spot. and there will be plenty of pics, when I bought this truck it was a long bed so Ive got plenty of pics to put up.
  4. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I would get a 3" or so body lift kit that comes with plastic blocks. Then it's easy to cut them to the length you need there on the spot.
