blazer factory speed sensor
Discussion in 'The Garage' started by dougyfreshh, Oct 9, 2005.
  1. dougyfreshh
    dougyfreshh Registered Member
    Oct 7, 2005
    9
    cali
    Hi guys im new to the forums I was wondering does anyone know how to wire a factory speed sensor im doing a carb to tbi mod I pulled the speedometer sensor out of a 1988 sub it has four wires going into a light green plastic box one is pink, blk stripe / blk , white stripe / brown / yellow
    im using the painless wiring harness 60101 I know I can buy their sensor but im trying to keep it as close to stock as i can
    Thanks guys
  2. dyeager535
    26,975
    terminals 8,9, and 10 on the VSS buffer are all you need to run without cruise control.
    The wiring apparently changed between makes and years, as brown is usually what goes to pin A10 on the ECM, blk/wht is ground, and pink/blk is 10A ignition switched 12V.
  3. dougyfreshh
    Oct 7, 2005
    9
    cali
    speed sensor wiring
    your the man thanks for the awsome info
