Blazer Footcorners???
Discussion in 'The Garage' started by jd70ssclone, Dec 31, 2006.
  1. jd70ssclone
    jd70ssclone 1/2 ton status
    Nov 29, 2006
    125
    baltimore
    i have a 86 k5 and the passenger side has a corner that is rotted out it is located behind the bucket seat but in front of the back seat ( wear you wouldput your feet if you were riding in the back. if you look in the rear wheel well you can see this peice anyone have an idea if this peice is available beaucse i need it bad thnaks
    JOSH
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    It sounds like it is part of the cab (if it's the floor you're describing). You will need to weld in a piece from a donor cab if you want it perfect. Otherwise, weld in a regular piece of sheetmetal and get creative. HTH.
