blazer front springs vs pickup front springs
Discussion in 'The Garage' started by mudhog, Jun 6, 2003.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    blazer front springs vs pickup front springs are they the same or are the truck ones longer?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    actually what i should have asked is will 77 blazer front springs replace the front springs in a 79 pickup?
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    front's are the same length.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Same thing. Just the differences in some springs are 2 and 3 leaf designs.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI Prior to 73 the front springs on Blazers and trucks
    are not the same leght as 73 to 91.
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    My 79 blazer front springs were crap, negative arch WTF? I much prefer my 5 leaf spring pack.
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    blown shocks will make the springs sag too, yea nuthin is better then 5 leaves up front /forums/images/graemlins/thumb.gif, btw what was the deal with GM useing a 9\16ths bolt on the rear spring shackle on the front leaf springs on the 91's i saw this and i feel inferior, because my 87 has 7\16ths bolts on that shackle.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    negative arch is normal and stupid. Try having a negative arch, bad shocks all around and a 6 leaf HD rear pack giving you an 1 1/2" rake on a k5. Sometimes I think it looks good most of the time I don't. My rear pack is so heavy that it barely squats with a couple thousand pounds on a trail behind it(doesn't even level the rake) but if I hit the gas the rear gets air off speed bumps.
