Blazer gas tank dimensions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Apr 28, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    what are the dimensions of the gas tank in a blazer and how many gallons is it? also can you use a pickup truck sending unit on a blazer tank?
    thanks
  2. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    My 31 gal tank is 27"x27"x10" deep in the deep end. Reason I know is that I had to frame out an opening for it in my new frame! /forums/images/icons/wink.gif
    Hope this helps
  3. dyeager535
    26,979
    Two different size tanks..the 31 was optional AFAIK, while a 22(?) gallon was standard. Sorry, can't help on dimenions, but with a sheer guesstimate, would say that its pretty likely a truck and K5 sending unit would interchange...lot cheaper to use the same sending unit on everything if possible, and depth is the only thing governing interchangeability. The truck tanks and K5 tank (at least 31 gallon) appear to be the same depth, at least by eyeball. You could always call the dealer and ask for the sending unit part #'s for a K5 and K10 of the same year.
  4. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    cool thanks for the dimensions and the info...
    anyone know the dimensions on the 22 gal? looking for a gas tank to put in my pickup where the spare tire goes(that might get bobbed)
    thanks
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    25 gallon 28.75 x 28.125 x 10.75
    31 gallon 28.75 x 28.125 x 12.75
  6. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    Was the height calculated at the point where the sending unit fits into the hole in the tank and measured down to the bottom of the tank?
    Thanks.
  7. British Slave
    British Slave 1/2 ton status
    Jul 25, 2007
    2,083
    Gonzales, Texas... The home of Texas independence.
  8. Silverado_K5
    Jun 4, 2003
    707
    Weston, Oregon
    I thought it would be, but thought I better ask first.
    The PO of my 84 K5 blazer thought the tank was a 25 gal tank, but since the tank is 12.75" tall, the measurements I came up with calculated into the 31 gal tank.
    Thanks,
    Doug
  9. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    Hmm. I guess my suburban only has a 31 in it then. Because I measured it last night at 12.75" deep. I always figured it was 38 or so.
