Blazer going on a diet.....some initial weights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2Blazer, Jun 21, 2001.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I know this topic is a little old, but just thought I'd share the weights of my Blazer and the top. I'm trying to get rid as of much weight as possible without doing anything radical and thought I'd keep track of what everything weighed.
    The basics of the truck are as follows:
    '90 K5 Silverado with all the factory doo-dads (air, cruise, power, etc..), 6.2 diesel, 700r4, rear 14 FF, front 8-lug 10-bolt, 15x10 steel wheels and 35x12.50 tires.
    The weights include all of the normal trail stuff I carry including tools, spare parts, extra fluids, hi-lift, fullsize spare, etc.
    Initial weight - includes top and full tank of fuel, but no driver or passengers:
    front - 2,880
    rear - 3,010
    total - 5,910
    I always knew Blazers were better balanced than pickups, but I didn't expect the rear to actually be heavier. I would also assume this particular vehicle would be on the heavier side when it comes to stock vehicles because of the diesel and all of the options.
    Remove top - on my '90 the topper has provisions for the rear seat shoulder belts to be bolted to it which adds some weight, plus it has the sliding side window.
    front - 2,900
    rear - 2,800
    total - 5,710
    As you can see, the top should weigh right at 200 lbs. for this particular model.
    The next step will be removing the rear seat (which was taken out last night, I'm estimating about 50-75 lbs.), replacing the rear tailgate with a pickup tailgate net, and losing the doors.
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Hey, cool idea! Keep us posted; years and models may vary, but this gives us all a ballpark estimate on vehicle weight and what weighs what.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    What is your GVW? My '83's is 6100 lbs, equiped similarly to yours, -power front windows and sliding rear windows.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Man these things are oinkers! I've yet to remove the doors, I've gutted the tailgate of the window mechanism, it has not heater or AC and it's 6600#. I'm curious about the doors, I know they're heavy, and the tailgate shell has some weight to it also. Past that, I can lose the top and start buying 'glass for the front end. I'd be ecstatic to get it below 6K with no people in it, but I doubt that will happen. It just seems hard to put a K5 on the trail under 6K lbs.
    Making the world better, one truck at a time.
    [image]http://coloradok5.com/logo_ordsmall.gif[/image]
    SW-ORD
  5. Grim-Reaper
    7,385
    Atlanta
    You don't think that 150ft of DOM, 39 inch tires, 600lb 14 and 700lb 60 might have a little to do with the wieght do you?
    hehehe. I'm surprised yours isn't heavier.
    My 79 with trail gear and camping gear and my fat butt was 6200. 6600 lb as built as your truck is sounds not to bad.
    I have as yet to weigh my 75. Maybe I can do that Sunday.....I'm almost scared to know. I'm the leader of the over kill club...Front bumper is about 200lb alone. My replacement gate is about 200lb too.
    I hear those Bummer kits shed about 2,000lb.
    It's not my damn planet monkey boy!
    Grim-Reaper
  6. DaveDave
    DaveDave 1/2 ton status
    Feb 8, 2001
    247
    a complete front dana 60 is ONLY 514lb.
  7. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Have you actaully pulled off a door full w/windows etc...
    Those sunb!tches are heavy! Theyve got to wait a minute...ok just weighed one and it comes in at around 75lbs. without speakers and power stuff(manual locks and window) My god theres 150lbs alone.
    Chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I weighed mine before I bought a trailer, 5700 lbs. w/the hardtop & Swampers, no gas, people, rear seat, or gear of any kind. Stephen, I think your problem is the doubler. If you are really serious about saving weight, I would trade you my 208; I'll even throw in the short shaft parts. I understand that big blocks are pretty heavy too. :D
    Pete
  9. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Keeping it under 6K with no people in it is also kind of my goal. I'm hoping to drop it down to around 5500 lbs. as it is currently set up, basically get rid of all of the non-essential items. After that I'm sure the weight will jump back up when the winch and custom front and rear bumpers go on.
    I'm hoping to find out what the weight is when an S-10 type body is bolted onto the fullsize frame. We now have two guys in our club with this setup, one is an '71 Blazer chassis with an S-10 Blazer body (44/12 bolt, 350, 4 speed), and the other is a 3/4 ton pickup which was shortened and has an S-10 extended cab body with no bed (14/Dana 60, 454, th400 auto).
  10. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    6600#'s? Don't worry, be happy. Local guy with a big F@rd Bronco, 460, 4spd, NP205, D60 front (coil), D70 rear, 38" SX's on 16.5's, weighed his. Some 7800#. Not a typo, 7800. And he doesn't have much of an interior either.
    --Rob
  11. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I like this post! Somebody needs to take each panel off of their K5 and weigh it.[​IMG]
    Stephen if your worried about weight you should swap out that pig doubler for an Atlas II. While your at it maybe you could whittle down that 50 lbs of shifters you have on the floor. [​IMG]
    Just kidding, that is one nicely built truck and congradulations on your success at TTC.
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
  12. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Stephen if you're worried about weight you should swap out that pig doubler for an Atlas II. While your at it maybe you could whittle down that 50 lbs of shifters you have on the floor. [​IMG]
    CB
  13. ROCKBUGGYK5
    ROCKBUGGYK5 1/2 ton status
    Jan 2, 2001
    170
    TEXAS
    dana 60 14 bolt 400 small block, turbo 350, np203
    38.5 sxs 15x10 mrts
    4000 pounds
    thats not a typo someone beat that
    bahahah
    ROCKBUGGY K5 38S LOCKED AND CHOPPED
  14. Ryeguy
    Oct 30, 2000
    Victoria, B.C.
    4000#? Now that's impressive, very impressive! Is it roadworthy? Kinda doubt it. Geby Wager, with the Gama Goat CJ that won the tough truck challenge a few years ago is obsessed with minimizing weight on his truck, so he can keep on top of the snow but keep it streetable. It's still a 512ci Caddy ('cause it's the lightest big block without going aluminum - $$$$), T-19, NP205, air suspension, 44" Boggers (for that extra inch of width for floatation), and he's gone the extra effort to trim weight in _every_ respect without losing strength that he thinks he can - custom frame, no radio, etc. He weighs in at about 5000#.
    --Rob
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    estimated via bathroom scale
    new L/R factory fender for K5 - 65 lbs
    factory rear seat - 75 lbs
    Factory front bumper w/brackets - 45 lbs
    Smitty built roll cage - 115 lbs
    L/F fender (including wasp nest) - 30 lbs
    - Does anyone know how to get a highly p!ssed off wasp nest out of my garage?
    O.K. I got rid of the wasps (smoked out)
    Ramsey winch - 105 lbs
    Core suport - 50 lbs
    Th350 auto trans (less converter) - 125 lbs
    Torque converter - 35 lbs
    Cast cyl heads - 50 lbs<P ID="edit"><FONT SIZE=-1>Edited by Twiztid on 06/21/01 10:42 PM (server time).</FONT></P>
  16. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Full of fuel (31 gals) with me sitting in it, truck weighs 5980-6030 including 200lbs. of tools & spare parts. Fiberglass hood helps as well as no back seat.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  17. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    After that little battle with the wasps, I weighed the rest of my junk I had laying around. Anyone know how much a 203 or 205 weigh? I've heard the 203 is around 200 + lbs. Or better yet, how much does a doubler weigh in at?
    Twiztid
  18. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    These are approximate, but should be close
    NP203 complete is about 175#
    NP205 complete is about 130#
    NP203 with Doubler kit installed is about 105#
    Complete Doubler is (130 + 105) about 235#
    As for some of these other jabs, there's only 125-ish feet of tubing, 2x.120 that is......And probably only 40 or 60 of other smaller stuff. If you don't count the link arms, which are pretty beefy. The lower arms are 3/8" wall thickness in the middle. oink And of course the extra beefy Tera 60 front center section didn't help, or the 3 1/8" x .500 wall DOM tube for the tubes.
    I know the shifters may be a little excess, but the 5/8" cold rolled is proven and I didn't want to mess with tubing for them. And I have to shift it all somehow!
    I think the high lift, pull pal, power tank, cable comealong, recovery straps, snatch block, etc, and the spare 42 on steel wheel may have something to do with it.
    But I usually have all the stuff I need to get me and every one else out.
    oink
    Yeah, the 383 would probably continue to push it around OK, but knowing we were going to TTC this year, and what a throttle fest that is pretty much put us over the edge on the motor. I used headers and an aluminum intake (in a whiney voice, like that's going to turn the rest of the iron into something lighter)
    Really, I got to the point that I decided that it's an oinker no matter what I do, so I might as well build it to where it will hold together. Anything I take off from here will only help. It was probably 5900 before I did the last go-round, so we didn't do too well, but it's all pretty beefy. NOT BREAKING was the priority.
    Later guys
    SW-ORD
