Blazer Interior Panels?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by darrel, Oct 4, 2002.
  1. darrel
    darrel Registered Member
    Mar 25, 2002
    16
    South Carolina
    Do they make reproduction interior door panels for 70-71s without the wood grain trim at the top. Apparently every 70-71 Blazer I have seen has panels that look exactly like 70-71 truck panels everyone sells, but without the chrome/wood trim.
    The 67-69 panels are close, but they dont have the bare space at the top. Trying to match as close to stock as possible.
    Also does anyone make or sell rear interior bedside panels?
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I have seen the repro panels listed in a few catalogs, but I have never actually seen them. Where did you find the ones you are looking at?
  3. darrel
    Mar 25, 2002
    16
    South Carolina
    I've seen the door panels in almost every 67-72 chevy truck catalog I have (LMC, Classic Ind., Chevy Duty). If you are speaking of the rear panels, I have not seen them personally. Just hear about them on the boards. Heard they were pretty pricey too.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Suggestion - build your own like these............
    /forums/images/graemlins/thumb.gif
  5. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I got mine at LMC. They are plastic and easy to clean. They have the bare spot at the top like it sounds you are looking for. Here is a pic. http://jt-k5.rockcrawler.com/images/dash-small.jpgI don't have the arm rests or cranks on yet, but you can see if they look right for you.
    JT
  6. ta70cst
    ta70cst Registered Member
    Nov 14, 2001
    28
    Colorado
    If price is an issue do what i did.. (i am not sure what color you want your interior) Find used interior walls that are in good shape (they can be dirty that is no big deal) and purchase vinel spray paint in the color that you want. Gently clean the used interior walls and repair any rips with Super glue... then carefully spray paint each wall.
    I did this last year and mine acually looked better than the ones I had to buy with the "wood" on top.
    This saved me a ton of money and they look great. I got my vinal spray at checker auto..
    Hope this helps,
    Tom /forums/images/graemlins/k5.gif
  7. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    Nice setup. I am actually currently doing a similar setup for my rear panels on my 69 although I am going to Herculne them instead of carpet b/c I keep my top off most of the time and use my truck for trails etc (makes it easy to clean). How is the particle board holding up?
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    chevy duty has them.the wood grain thing i think is just a decal you buy seperate.so if you dont want the woodgrain then you can buy just the door panel.
  9. BurbinOR
    5,829
    Oregon
    No issues with the particle board, but I don't leave the top off and let it get wet either................. /forums/images/graemlins/smile.gif
  10. Bill4rest
    Bill4rest 1/2 ton status
    Jan 12, 2002
    103
    Vista CA. (so cal)
    I like it, when I get around to finishing the body work I'll be doing the same thing.
  11. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    I use a heavy grade particle board. I had the top off all summer with various weather (moisture, direct sun) and had no problems. I'm actually going to redo them once I get my new amp that will go on the opposite side. I post pics then.
  12. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    I was just looking at the catalog from Pickups Northwest last night and they have "custom" blazer side panels. I think they are mostly targeting the lowered/hot rod crowd. The photo wasn't very good so it is hard to see what they actually look like but they were listed at $299 (may have been $219). I don't think they are on the web site but you can get their phone number there if interested. http://www.pickupsnw.com/ /forums/images/graemlins/pimp1.gif
