Blazer jumps when i put it in gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Aug 8, 2000.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    When i put my Blazer into gear, be it park to drive or reverse to park. It doesn't really do it from park to reverse or drive to reverse. The idle is fine so its not that. I have replaced the side gears in the carrier and the u-joints, but still no fix. Someone help!
  2. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    can anyone help?
  3. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    tough question, have you checked the tranny crossmember...maybe the bolts are loose?
    Kelboski
  4. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    I have checked all the bolts. could it be the chain in the transfer case is streched?
  5. Kelboski
    306
    Mcdonough,Ga
    i don't know much about that, but why would the truck jump, if the k5 was in 2wd...considering the chain was stretched? there are guys on the site that can help you if you keep the post updated. sorry i can't help..wish i could...keep us updated after you find the cause.
    good luck..Kelboski
  6. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    anyone else got an idea?
  7. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    It`s not the chain on the tranfarecase because the chain is only used when you are driving in 4wd.
    I can`t help you further.
    River `89 K5, 350, TH700R4, NP241, "33, 2.73, 10 bolt F, 12 Bolt R
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It sounds like the tranny. Usually reverse starts going out first. When you shift to reverse does it not engage for 2-3 secs and then jump into it? This is probably the tranny slipping. Make sure the fluid level is right and you should put a cooler on if you dont have one already
    90K5
