Blazer K5 1987 4x4 6.3 Diesel
Discussion in 'The Garage' started by tgkwb, Nov 10, 2005.
  1. tgkwb
    tgkwb Newbie
    Nov 7, 2005
    Norway
    Hello,
    my car won`t move so I have to take down the transmission (TH700) and the converter. Can someone help me, I need a plan for how I must do this. I`m pretty green on this level. I have someone who will fix it for me, but I have to take it down first. Please if anyone could help I be greatfull.
    best regards,
    Tor.
    Norway
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Unbolt the driveshaft U-joints from the pinions, unbolt the front driveshaft from the transfer case. Slide rear slip-yoke out of tranfer case (transfer case will spew). Get jackscrew stands (if on a lift) or a transmission jack, and support the transfer case/transmission. Unbolt the crossmember and remove it. Unbolt the bellhousing, pull out dipstick tube (transmission will piss). Disconnect cooling lines (transmission/cooling lines might piss). Use a flywheel wrench (or go the front of the motor), turn the crank until you can get to the torque converter bolts. Rotate to get to all the torque converter bolt. Find a large crowbar to pry the transmission bellhousing and use the jackscrews or transmission jack to lower transmission.
    Am I missing anything?
    Oh yeah, you might want some safety glasses and air tools.
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Yep, forgot something.
    Disconnect the shift linkages for the transmission and transfer case, the TV cable, and the speedo output from the tcase tailshaft. :)
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Don't forget the TV cable, I've forgotten that one a few times now...
