Blazer lift opinions/help wanted
Discussion in 'The Garage' started by Bunker Buster, Mar 31, 2005.
  1. Bunker Buster
    Bunker Buster Registered Member
    Jan 25, 2005
    36
    Lowry Crossing, Tx
    I have just about gathered everything I need for the lift for Buster(M1009), except shocks. Those will come next week. I'm lifting the truck to clear 35/12.5/15's. For the front I have Tuff Country 4" lift springs with 1" Zero Rates. On the rear, we are doing a shadetree shackle flip and keeping the stock springs. I understand that the flip should net 4" of lift. My question is how much should I lift the rear to keep it level? With the diesel, and stock springs all the way around, it sits level if not a little a$$ high, which is not typical for a Blazer.
    I am a stickler for doing things right the first time around. So would I be better off lifting the rear the same 5" or going 6-7"? To get 5", I would do the flip+Zero Rate. Otherwise, I was thinking about a flip+drop shackle to get an additional 2". I'll also be using shims to keep the pinion angles correct front and rear.
    Thanks for the help.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I can only tell from my experiance - 5" springs in the front and 4' shackle flip + zero rate in the rear. It sat level before the lift.
    Rear sags just a little without a load and a lot once the truck is loaded. I am going to boost my rear another 2" or so with either booster springs or new springs altogether. Every truck is different, but mine needs a little extra in the back.
