Blazer or Jimmy?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BamBamblazer, Jun 24, 2002.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    I have an 84 Blazer that the tub is more rust than metal, i have found a jimmy body that is in good shape and my question is: are they exactly the same other than the name? body mounts in the same place and all that?
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'm pretty sure it should bolt right up.
    John
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    As far as I know the only difference is the grill /forums/images/icons/wink.gif
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    More than just the front grill!
    there are very very important differences!
    Hood emblem, side emblem, rear emblem, oh yea, I think the steering wheel has GMC instead of the Chevy. /forums/images/icons/smile.gif
    Other than that, it should be the same!
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Body and tub parts are all the identical exact same thing.
    The difference between GMC and Chevy are the decorative stuff, like the exterior trim, interior pieces, etc. etc. /forums/images/icons/wink.gif
  6. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    It depends on the year of the donated "Jimmy".If it is '81 and up the mounts are all the same, older than'81 then the mounts are diff.I just got done installing a '85 jimmy body on a '79 frame.Also the front and rear bumber mounts are different.Lotsa luck....it's not easy to swap bodies.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    484
    Grand Rapids area
    The question is: what goes on the title when you are done? /forums/images/icons/wink.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    You will go by whatever year the body tub is as that's where the i.d. plate is riveted to.
    Around here, they only go by the body. The frame does not have anything to do with the vin identification.
