Blazer ponderings.
Discussion in 'The Garage' started by DavidB, Oct 18, 2006.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Most of you know I'm not fan of Blazers (I prefer pickups) but I found a good deal on one. My questions are these:
    Yah, I know it's been discussed, but I wanna rediscuss. And I'm lazy. :D
    How much can you stretch the wheelbase before you hit the tank in the back, and how light can you get one? My brother's 1 ton K10 weighs 4,800#, I'd like to get around there. No top, no doors, no tailgate, minimal armor. Can the tank be moved up/back without much trouble to give more room for the rear diff?
    Thanks - David
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I think from looking at Ira's you could move the rear axle back about 4" or so before hitting the tank. You could mount the tank higher by cutting a hole in the floorpan and raising it a little bit (or a lot). It would be real easy to do, but could mess up any thoughts of putting junk in the rear.
    Weight..... I have no idea.
  3. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Depending on your diff and cover, moving the axle back may work.
    With my 14BFF and a Jethro-built cover, 4" was absolutely out of the question (the 56"s in the rear only fit with the short edge forward.) 2", maybe.
    With a stock diff and/or a shallower cover, 4" is prolly doable. Not much more.
    The tank can only move up if you cut the floor. Back, maybe, but you'd have to modify the bumper, fill pipes, etc etc etc, and that for maybe an inch or two.
    HTH.
    -- A
  4. bigpig72CST
    bigpig72CST Registered Member
    Oct 3, 2006
    5
    Des Moines, Ia
    Using a stock rear, I was only able to get 3 1/2 inches. I agree, 14ff would leave you much less room.
  5. readymix
    May 30, 2004
    6,706
    26
    What happened to the 3+3
  6. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    Loose weight and put the rear axle were you want = get a small fuel cell above the floorpan :waytogo:
  7. bigpig72CST
    Oct 3, 2006
    5
    Des Moines, Ia
  8. dremu
    Feb 27, 2000
    15,963
    454
    David (or was it Andy?) had a crewcab, aka sixpack, 3+3, etc, which was gonna be wheeling.
    -- A
  9. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Might still...might sell. Gimme yer CUCV :D EDIT: Nevermind, it's not a 1008
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think I can move my 14FF back 4" by flipping my 56s around I do not understand the concern of the fuel tank as the dif does not move up and down as much since the axle is articulating around it. I do not jump my rig but it does slide off of rocks sometimes. Has anyone actually hit there fuel tank with the rear pushed back? I cannot raise my tank as I still run a top. I suppose I could fab a false floor behind the rear seat so the tank is still "under" the bed of the K5:D. As far as the front axle it is really limited by steering. I think you can get 3.5" with 52s or 56s and a zero rate that will almost put your pitman arm directly above your spring plate which on compression could be a bad thing. That would make the overall wheelbase of a K5 106.5+3.5+4=114".
    Ira
  11. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Thanks for the good info. I was hoping to get the WB into the teens without a lot of trouble. Sounds doable. Mine will be jumped though :D Might keep the 60 and build a low-pro pan for it. Or go 14FF and do the same thing.
