Blazer prep for Autumn thump
Discussion in 'Southeast Region' started by steve_kibbe, Sep 21, 2006.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Here's my list, how about yours?
    Zero rates in rear DONE
    Mount tires on wheels DONE
    Tool box buy/mount
    Steering box brace
    Accumulate spare shafts/hubs/ujoints
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Thats alot better than your prep list for tellico:doah: :haha:
  3. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Yea, different blazer:D
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Get tires mounted - done
    Finish/mount rear bumper - done
    Finish/Mount tire carier - done
    Finish/mount sliders -done
    Wire front Hella's - done
    Bleed brakes - done
    Change fluids - done
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    #1. Try to not tear anything up before I get there. :rolleyes:
    Still have the dented drive shaft from Tellico actually. Haven't had been able to afford to get it fixed or buy another. So, light throttle at Uwharrie fer me..............:mad:
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Donald you've got a TH350/NP203 right? I've got one rear shaft for that stock setup, so I'll bring it just incase you or CB may need one. I need it for a later project but I'll bring it for a backup for yall.
  7. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    My list:
    1- Finish grinding, sand blasting and painting the new hummer rims.
    2- Then dismount the tires I PAID to have mount before Tellico
    3- Mount the tires on the beadlocks
    4- Swap the new alternator in to the truck.
    5- Alot of 'other' junk...
    But the weather has turned real nice for working on the truck
  8. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Install winch - NOT HAPPENING
    Find front receiver hitch - FOUND, NOT DONE
    Build and install front hitch- NOT HAPPENING
    Install rear bumper - DONE
    Install extended brake lines -DONE
    Install CB - DONE
    Install CB antenna - DONE
    Install lights - - NOT HAPPENING
    Install passenger seat - DONE
    Motor Mounts - DONE
    Install rear u-joints- NOT DONE
    Change out steering pump- NOT HAPPENING
    Maybe dual batteries. - NOT HAPPENING
    Pick up 14bff and wish I could get it installed in time - PICKED IT UP, STILL WISHING
    35x14.50x15 Tires - DONE
  9. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    to do:
    find a u-joint for the rear drive shaft-
    install chip -DONE
    set timing -DONE
    install rear axle 14sf-DONE
    install govlock-DONE
    change front 10bolt 6 lug to 8 lug-DONE
    put new gaskets in np205 and seal in adapter-
    pickup rims,tires and govlock (this weekend) -DONE
    have about a month and 2 more paychecks :thinking:
  10. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Repair tail light wiring
    Pray front shaft doesn't give out because the guy welded it off center slightly which explains the vibe I get on the highway
    Try to get running better. I think I need a new harmonic balancer.
    Repair fog light wiring for the NIGHT RUN!!!
    Repair oil leak from engine AND hard line to my gauge.
    Find a body bushing and retainer so my front bumper doesn't flex all over the place like it was at DPG.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Thanks brother!!! :D
    But, the 203 busted 5 days before ECBB05 last year and I had to put in another 350 Turbo and convert to a 208. That's one reason I was a bit timid last year. Test drove it on the way there!!!
    Had to get a P/U driveshaft cut down to fit. I've got another K-10 one but it will have to wait. The dent is right at the bottom u-joint, so it ain't as likely to twist up as it would nearer the middle.
    Thanks again brother............you the best!!! :bow: :bow: :bow:
  12. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Is it slip yoke? If so I've got one of those maybe. Give me a measurement.
  13. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    - change oil
    - check CK5 periodically for updates until 20 October
    - load up wifes truck
    - place wife in drivers seat and giver her directions
    - arrive at URE for fun and enjoyment:D
    (its not a blazer, but it gets me around)
  14. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  15. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, I ain't found a SYE for the 208 yet, and the funds! :wink1:
    Sure man, I'm at work today till 7:00PM though. :mad:
    Kool, I might get to make a withdrawl from the Parts Bank Of Clark! :D
  16. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    If the one I have is not the right size I believe I've got enough stuff to make you one.
  17. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Adjust the rear shock mounts
    Cut the overload springs.
    Bump the timing down slightly
    Re-tighten header bolts
    Hope I can afford the trip
    -Harrison
  18. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Cool Beans :D Thanks
    To do ....
    PS cooler Done
    Fix gas gauge Done
    Install new hood Done
    Modify front rack
  19. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You can do that while you're there!!! :wink1: :D
  20. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The one I had made is 31" center of cap to center of cap. :o
