Blazer Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biggedraws, Nov 2, 2001.
  1. Biggedraws
    Biggedraws Registered Member
    Apr 13, 2001
    57
    Gilbert, arizona
    My 86 Blazer will not go into gear.. I pull the shifter down into any gear and it acts like its in neutral... Is this just a bad tranny or something else?
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Did you just get done installing a body lift ?
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  3. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    Check the tranny fluid for discoloration and a burnt smell. The tranny oil should be a strawberry red and should not smell burnt at all.
    Also make sure your T-case did not get bumped into the nuetral position...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    sounds like youve got a 700r4!
    would you mind un-wedging your fullsize from between those trees? your blocking the trail.
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Mine did that awhile back and it turned out to be the pin that connects the manual selector to the valve body. I had to drop the pan and replace the wire pin. Hopefully it's something that simple!!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  7. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    it is a 700r4 :(
  8. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    the truck started givin me problems about a week ago... i would put it into gear and it would move verrrrrrrrry slowly. i left it at a gas station and came back the same night and replaced the tranny fluid and filter because it was black. it worked fine goin into gear but 1st and second gear were messed it had to be real high in the rpm's to change gears and when it did it would jerk real hard. then i was comin home from a friends house and turned into my neighborhood and it wouldnt go... it was like it was in neutral. i checked the fluid and it is pitch black again... i dont know what the hell is worng.
  9. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    Well looks like im gonna need to buy a new tranny or get a rebuild kit... anyone have an idea on what i should go with? its a 350 with a TPI right now it has a 700r4.
  10. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    One word - RAPTOR
    ...or find yourself a nice 4L80E.
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>U.S.S. Nimitz II</a>
  11. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    TCI, or be a bastard like me and have one from 1991 (just found out the other day, so I'm real happy) Actually in the last few years (89 up) they did even more improvements and made them alot for reliable
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'd get the 700 rebuilt. Put a cooler on it, and change the fluid regularly. They usually cost about $1200 to rebuild, and you can get some better parts put in it so it will last longer...
    90K5
  13. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Have you checked your tv cable. It's more than just for downshifting. If it is out of adjustment your tranny will do all sorts of neat tricks you thought were impossible. And it's cheaper than a rebuild.
    Shawnboy.
    If you are having too much fun it's probably illegal.
