blazer rear floor support
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grnddwn, Mar 3, 2002.
  1. grnddwn
    grnddwn Registered Member
    Feb 23, 2001
    7
    I need the rear cross support on my 72 blazer and I don't know where to find one. The truck ones don't work as far as I know . Can anyone help Thanx
  2. 2manychevys?
    2manychevys? Newbie
    Mar 3, 2002
    I have a post up asking the same question. I have a truck ('72 fleetside longbed) rear floor support in good condition. The construction & measurements look the same. The only differences I see are that the blazer support has 2 areas cut out for the frame to pass through & the frame supports are ''boxed'' where the bolts/bushings go through. Looks like it should work? Anyone?
  3. blazin79
    blazin79 Registered Member
    May 26, 2000
    43
    Pocola, OK
    the truck one should work with a little modification. Or you can probably get one from LMC truck. Good luck.
    Tracey
  4. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    You might want to try Raybuck in Punxsatawney, PA as well. The have a website. I think www.raybuck.com - I don't remember for sure. I called about a similar item for my Suburban a couple of years ago and he told me to wait and that one was coming out. A year later, LMC comes out with a new Suburban catalog and there it is!
    I always like a guy who'll be straight up with ya!
  5. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    JC Whitney sells them. along with new florrboards and more
    NITRO
