blazer rides rough; RS5000's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 12, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    blazer rides rough; RS5000\'s?
    Ok, I just want to see if other guys running the RS5000's are having a real harsh ride. When ever i go over any bump in the road, i really feel it. My truck is lifted but im unsure of how much lift exactly and what springs i have(bought it that way), i have a 4" block in the rear with an add-a-leaf it looks like. It is very very harsh.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Re: blazer rides rough; RS5000\'s?
    I have the 5000's and a 4 inch with blocks out back and the ride isnt to bad, actually I think its pretty good, UNTIL I go over some bumps or down a street that has been "repaired" or railroad tracks or something.......VERY harsh, sounds like the truck is going to come apart. I cant even imagine going down a washboard road[​IMG]. I dont really have anything to compare it to as this is my first lifted truck. What I have been told its the shcoks. I would say 95% or higher of the people on this site, hate the 5000's and say they ride stiff as hell. It just seems to be the shock NOT to get. If you cn afford it go with the 9000's, adjustable and alot of people like those here, but they are pricey. If you want something less expensive, I have heard good things about the Trailmaster SSV's. A couple members are going with those soon from what I've read. I'm curious to here what they think. And if you do have add-a-leafs, I'm sure those arent helping the situation either. Just my $.02
  3. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Are your body mounts good? I just did mine and the truck feels new.
    1988 Chevrolet K5
  4. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    well, i havent checked the body mounts, probably the stock rubber ones. I should replace them. How hard is that to do. I also would really like to get the 9000s i guess its time to start saving
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Listen to 90blzr. He knows what he's talking about.
    I have the RS5000's on my '85 K30 and I HATE THEM!!! [​IMG]
    I wished I would have gotten the RS9000's instead. I'm stuck with these 5000's for now because they are only approx 6 months old. [​IMG]
    For about another $100, you can get the 9000's and adjust them to YOUR specs.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I have them on both the 93 Burban and the 72 Blazer and I hate them too!
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I have the RS5000 on my '90 and really don't care for them. I run Skyjacker on my '88 and the difference is night and day. Try'em I know you will like 'em.
    Shawnboy.
    If you are having too much fun it's probably illegal.
  8. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    What would happen if i removed the rear shock absorbers? I know i would get a softer ride but at what price, would i lose a lot of stability? I have my top off now so there is not too much weight back there.
  9. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Rancho shocks are lifetime warranty. I run the RS5000's and they are O.K. If you go to the RS9000's get the in-cab controller. Extra money but i here its worth it. Most places require original invoice to warranty though.
  10. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    To be gentle here, RS5000's blow dog - get rid of them!
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  11. Storm Trooper
    Nov 24, 2000
    4,640
    I have 5000 and although I don't think much of them, my truck rode like a tank until I changed the front springs to easyride and replaced all the spring bushings with greasable ones. It made a 150% improvement. Talk to Stephen at ORD. He will set you up. You can also check the spring bushings 1st to see if they are rusted up and don't give. If the springs can't flex, it doesn't matter what kind of shocks you have.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"8" Lift -<font color=purple>38.5's"[​IMG]....
  12. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Lets see. Here's my suspension setup...
    Front = 4" Tough Country EZ rides with RS5012's, ORD Longer shackles, Greasable bolts and bushings.
    Rear = 86 K5 Springs with ORD 4" Shackle flip with greasable bolts and bushings, and RS5012's on them relocated on the axletube and custom crossmember made.
    My ride is exceptionally soft and I love it. I just dont understand everyone complaining about stiffness. Do you honestly expect your K5 to ride like a car? Mine in no way does and from the previous suspension setup its like night and day. I had Rancho springs up front and 74K5 springs in back with 4" blocks. I can honestly say that it is more the springs that cause stiffness than the shocks.
    My 2 cents
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I ditto Waxer's comments. It is the springs, not the shocks. I have 5000s on stock suspension on my Blazer, and if anything, they are TOO SOFT.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It may be that the springs are too stiff (like mine) but a better shock can only help the ride IMHO.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
