blazer roll cage???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin_willy, Jan 24, 2003.
  1. wheelin_willy
    wheelin_willy Registered Member
    Jan 23, 2003
    24
    does now if a blazer roll cage exists out there?(or at least something to protect the rear passengers with the top off) i like doing things myself and realize there isnt a bolt-in deal.
    i just dont want to spend 2500 for someone else to do it
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
  3. wheelin_willy
    Jan 23, 2003
    24
    thanks for the site . it only offers a cab cage and nothing for the rear.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    There is a 10 point cage available. BaBlazer73 has one and it's a full cage.
    Rene
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Smittybuilt(sp?) makes a passenger/bed bar that fits under the hard top.
    John
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    this is the cage that I'm planning on doing. I think its the best bang for the buck.
  8. JayHornyak
    JayHornyak Registered Member
    Feb 15, 2001
    18
    Clinton Connecticut
    I have the smitty bult roll bar and it is not too bab it rides about 4" bhind the rear of the cab into the shell of my 89 I wish it was more behind the rear seat though. /forums/images/graemlins/k5.gif <font color="brown"> </font color>
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've been talking to Echobit to make me a rear hoop and a mid hoop for mine. Then I'm gona build the spreaders and build some triangulation into it myself. I like to do my own stuff to whenever I can. I don't have a bender so I contacted Echobit for those peices. I think he is probably already working on some 3d models for me. I can't wait to see them. This is an option for you though. The guy at Echobit will tell you straight out though that shipping is gona suck cause when buying hoops only you get the bulk of the shipping charges due to size of the hoops. Give him an email. Nice guy to work with.
  10. blzn1
    blzn1 Registered Member
    Apr 9, 2002
    76
    SO-CAL
    dude, that roll cage is sweet!!!!!!!!!!!! I went to his house the other day and saw it is grade A quality. cool dude too!!!
  11. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Kert, I just mailed you some starting points to build on. From here we just move things around, bend here and there until you get it where you like it... sneak peak?
    Rick's (Blz1) Blazer looks pretty good, fresh engine, 35's and locked in the rear. He had me drooling on his Thorley Tri-y's the whole visit - I should have wiped them off before he left! /forums/images/graemlins/thumb.gif
  12. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    so how does the cage attach to the truck? Is that also a bolt in deal? Does it just attach to the body, or does it somehow find it's way to the frame? Now you've added another item to my wishlist /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    There are a lot of options when it comes to attaching the cage which is why I only supply the flat plates with bolt holes and hardware. My preferred method is to flat plate the bottom of the tubing with 4 bolt holes and drill the body for the bolt holes. On the opposite side you would add an identical flat plate with matching bolt holes, run 9/16" bolts for a pinch fit. You could run tubing from there down to the frame. At the frame, I'm torn between adding a bushing mount or solid mount (depending on the application). I like this route best because it gives you flexibility in removal and potential upgrades in the future without getting too permanent. Some gotchas there are in clearance at the bottom of the body where body mount beams can get in the way and effect hoop placement for tying it down. This is why I chose to weld my cage to the floor above the body mounts. Having a 79, my full top over prevents the cage from ever being removed anyhow, and adding cross tubing to mount the seats will prevent the cave from poking through the floor in a roll over. The half top models are my biggest reason for making a completely bolt together cage so that it could be assembled or removed without any problems... in fact, it can be assembled in the truck without really removing anything for the installation.
  14. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Not a good idea to use identical plates. They should be diff sizes or shapes. If the plates are identical it fatuges and cracks the metal around the plates and it makes it easier for them to tear out
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think it looks great. I got lots of ideas bumbling around upstairs. I just can't wait to get at it. Thanks again Mike.
  16. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Your absolutely right. I did say identical plates for the sake of discussion but when it comes down to an install, body supports and other obstacles in the floor almost never allow for identical plates or matching plate edges. All the same, its an important correction to point out.
  17. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If you call them, they can sell you another main hoop, that you will have to cut down and fit and enough extra tubing to do whatever you want. I got my cage from them and considered doing the back, but decided not to. What they suggested was another main hoop, and another set of rear support bars. Tie the top of each hoop together and run the extra set lower on the sides of the main hoops. Call them. i used to get all my race car cages from them. The will do most anything you want. just gotta call! [​IMG]
  18. k5lover
    k5lover Registered Member
    Sep 22, 2002
    47
    San Diego
    They sell Smittybilt weld in cage kits Here
  19. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    I figgured you knew that. Just wanted to help in the prevention of bootie-fab /forums/images/graemlins/grin.gif
  20. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    how much for the rear hoop and a front hoop at the A pillar? shipping to central CA (merced CA) how much if picked up?
