blazer seats
Discussion in 'The Garage' started by the excuse, Dec 15, 2003.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    i was just wondering but would seats out of a new tahoe, suburban, silverado, bolt into my 83 blazer? will they be the right height or will i have to jimmy it ito working? whats the easiest way to get new seats in and not have to fab up some crazy seat mount?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well if you measured and it will fit into the cab. Then the easiest way to fit different seats is to use the mounts from donor vehicle and drill new holes in the floorpan. I have van seats with armrests in my 83 blazer, taller and more supportive as well as had lumbar adjustment. Just simply bolted them with throughbolts into my blazer. Now if you got a rollcage in the future ( i want one ) then the best way is to run extra points to the cage where the seats are and bolt seats to rollcage.
  3. the excuse
    Dec 9, 2003
    209
    san diego
    do you think i would need to make some sort of a mount to raise the seats up more or would the factory bracetry be high enough? just asking because im begining to look into seating.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You can make almost any seat work for you. You just need to fab up some adaptor brackets. I plan on Captin swivel seats from a conversion van. You know, the big plush comffy ones.
  5. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    There are a lot of seats out there that you can make work. I put the seats out of a 95 Chevy S10 onto my existing 85K5 brackets and only had to drill a couple of new holes. They look great and are a lot more comfortable than the OE seats. /forums/images/graemlins/smile.gif
    It is also great to have the ability to adjust the seatback angle. /forums/images/graemlins/laugh.gif
  6. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I have seen this done before on a 86 blazer with new silverado seats. The only thing that didn't work was the mounts(easy fix). I plan on doing the same to mine but if you have a roll cage check to make sure the center hoop will not hit the integrated seat belts.
