Blazer Side Gas Tanks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kevinv, Jul 25, 2000.
  1. kevinv
    kevinv Registered Member
    Jun 28, 2000
    10
    Has anyone succesfully converted to side gas tanks and installed the spare tire underneath like the pickups?
    Thanks!!
  2. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    I wouldn't know for sure, but I don't think there's room.
    Canuck
    Go Wide or Stay @ Home
  3. azgmc
    azgmc Registered Member
    Jul 24, 2000
    9
    I for one wouldnt want to screw with it. Remember the stories of the 80's model GM trucks exploding when hit on the side?
    Besides, a 40 gallon tank at 8 lbs a gallon would be a bit much to have on the side of the vehicle...
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just in case anybody cares, the show that ran the footage of the Chev truck exploding on impact due to the side tanks later admitted that, for effect, they used explosive charges to ignite the tanks "just in case they didn't blow". I remember when they were forced by GM to make a public apology on a later show. Does anybody remember which show(60 minutes or one of those?) pulled the stunt?
    In addition, I've seen lots of pickups with side tanks in accidents that haven't exploded. And how many 70's cars with the tank way in the rear didn't blow when they were rearended?
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It was Dateline who rigged the truck explosion.
    YEEEEE HAWWWWW[​IMG]
  6. Can Can
    15,552
    136
    Thanks for the info, bro!
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Hi Kevin! Steve here....side tanks work fine on a Blazer. I have a home made set, 17 gal each. I did it
    for the range increase not tire relocation. I made cardboard mockups, then fabricated from
    16 ga steel sheet. Gas welded. I have friends who have done this too. Most have thru bolts to the
    body and another way is frame brackets. Here's the primitive spare mount method: (see attached)
    SteveB
