Blazer stalled, will not start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PolarBear, Aug 8, 2003.
  1. PolarBear
    PolarBear Registered Member
    Nov 30, 2001
    20
    Mesa, AZ
    I was driving down the street today and she just stalled. I could not get her to start back up. Pulled off the air filter and looked at the inkectors. They are just sputtering when it turns over. She would almost start and then, no more fuel. I thought it was the fuel pump, so I dropped the tank and replaced it with a new fuel screen.
    After all of that, the situation is still the same. It seems like she wants to start, but then nothing. The injectors are still just sputtering. I am at a loss... Any ideas??? Thanks.
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Does it have an inline filter somewhere? Normally along the frame rail under the cab
  3. PolarBear
    Nov 30, 2001
    20
    Mesa, AZ
    I checked that as well. It was replaced 8000 miles ago and seemed OK. I disconnected the fuel line at the TBI and there seemed to be plenty of fuel there.
  4. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    I had a problem like that, changed filters, even bought a new fuel pump. turned out it was a blown fuse that caused the switch to go into "neutral" between left and right tanks.
  5. PolarBear
    Nov 30, 2001
    20
    Mesa, AZ
    I only have one fuel tank so swithing between them isn't a problem :-)
  6. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Fuel pump... thats where my money is if the FUSE checks ok. I've had 3 different TBI'd Chevys' do that to me! The last one I changed in my Burb (with a FULL tank of gas) only took 3.5hrs! IIRC, the pump was $39 @ AutoZone... so its not that pricy to repair either.
    Good luck with it!
    -Dan
  7. PolarBear
    Nov 30, 2001
    20
    Mesa, AZ
    I have checked the fuses. All are OK. As I stated in the original post, I just replaced the pump, and the symptoms are the same. /forums/images/graemlins/confused.gif
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I don't read where you said the pump was replaced... just the "fuel screen." /forums/images/graemlins/ignore.gif
    -Dan
  9. ZK5
    ZK5 1/2 ton status
    Dec 16, 2001
    100
    Meriden, CT
    CHECK THE IGNITION MODULE. mine left me stranded 1 day
  10. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    I secoend the module, some auto parts stores will test them for free. Module is lcated in the base of the distributor. Might want to replace the pick-up coil while you are in there, it can cause the module to go bad prematurely. it is farily innexpensive. Good Luck.
    Jeremy
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'm with the Dist module crowd too. Pull it and take it to a auto parts store.I know Napa and Checker will test them for free. They are cheap to replace.
    On some FId trucks if the module is bad it will also shut off the fuel so you dont flood it out.
  12. PolarBear
    Nov 30, 2001
    20
    Mesa, AZ
    Sorry it took me so long to respond. I have been at Lake Powell. I checked the Ignition Module at Autozone and it was fine. It ended up being the pick-up coil. Thanks a million. /forums/images/graemlins/thumb.gif
