Blazer Steering Arm Removal
Discussion in 'The Garage' started by DuallyK5, Jun 9, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    I had a question about the cone washers. Are they just pushed on or are they somehow screwed on. I need to remove my drog drag link for a perferred Raised steering arm to help improve my turning radious and steering play. Any suggestions.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    They are just slid on over the studs. Read back 4-5 pages in the garage or do a quick search there was just a good post about removing the arm.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Where it says hit it with a BFH....
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Hit the arm with a big hammer to loosen the cones. You can use some channel locks/vice grips/pliers to maybe thread them off after they are loose. Otherwise, hit it more with the BFH.
  5. goldwing2000
    goldwing2000 Guest
    ... and a little heat never hurts. :weld:
  6. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i used the back of an axe - essentially a sledge. wasn't too bad. they do make cone washer pliers which can be helpful. one of the three cones on my arm wouldn't just pull straight off and i did have to twist it as i brought it up off of the stud, so the pliers came in real handy.
