Blazer Transmission-transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jan 6, 2002.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    ok i have a 1986 k-5 blazer with a 350ci engine the transmission that is on there is dying so i am going to drop a 4 speed manual that i have. So my question is will the transfer case fit and do i have to mod anything so that the transfer case fits on to the new trans. let me know thanks
  2. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    To answer that ? we will need to know what trans and transfer case is in it now.
  3. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    it is a TH700 with o/d and crap id have to drive the the garage my truck is in
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    It should have a 700r4/208 combo. If you want to swap to stick shift you will need everything including driveshafts to put it in a K5. Also you will have to make sure the crank in the engine has the hole in the end for a pilot bushing.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    is the rear drive shaft longer on a manual or shorter?
    also is front longer or shorter
    will the transfer case fit on a stick shift trans
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    It depends on what the 4 speed was out of. The older SM 465's were 10 spline output, in 81 that changes to 32 spline output. Regardless, the T-case you have now has a 27 spline input so it will not bolt up. Try and locate a 4 speed with the T-case still attached...then get the driveshafts built to suit.
    Another thing you'll need is all the pedal assemblies and all from under the dash. You'll need to find either the clutch master or get all the manual clutch linkage depending on which bellhousing you got with the 4 speed...
    Good luck
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  7. K5Psycho
    Jan 6, 2002
    55
    FL, USA
    ok thanks
