Blazer won't start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Apr 15, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    Blazer won\'t start
    I bought my first K5 friday and first vehicle for that matter. Its a 77 Blazer. It worked just fine up until this morning. It started once but would not start again. Sometimes it will fire but immediatly shuts itself off. The motor is a 350 but not the original. I think I got some bad gas. What do you think? Also, what are some cheap ways to increase power with out sacrificing gas milage? I'm thinking K&N.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: Blazer won\'t start
    Here's a couple of things to check out-
    Fuel pump
    Fuel filter
    Ignition module
    Needle and seat in the carb
    This is a long shot, but since you just bought the truck, do you know if your fuel gauge is accurate? Is there a chance you could just be out of gas? Don't laugh, this has happened to me before...........
    Give us a bit better description of the symptoms and it might help to narrow it down.
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. Jonathan
    Apr 14, 2001
    293
    I've got Gas. I put $20 worth of gas in it when I bought it and have only driven about 40 miles since then.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'd guess ignition module.
    90K5
  5. Jonathan
    Apr 14, 2001
    293
    How much do you think that would cost to fix?
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Your engine needs 3 things to run. Spark, fuel and compression. Compression generally is lost over time so that is prob not it. To check for spark take off one of the spark plug wires and stick a screw driver in it and hold it next to something bare metal on the truck. Have a friend crank over the motor to see if there is spark. If there is next try fuel. Take off the air cleaner cover and with a friend cranking it look down the carb and see if there is any fuel going into the engine and if the choke is working. Post what you find and we will go from there.
    '71 Blazer CST with alot of rust
  7. Jonathan
    Apr 14, 2001
    293
    I'm taking it to a mechanic tomorrow if it will start at all. Other wise I will try that. I don't really trust myself yet. I have to rely on it as a daily driver.
  8. Can Can
    15,552
    136
    Most of the things a mechanic will check for can be easily eliminated by you with a little time under the hood.........You didn't fill out your profile, I see- Are you green when it comes to vehicles? Well let us give you a hand, buddy..........
    To begin with, explain as best as you can what happens when you try to start the Blazer. Does the engine turn over? Do you smell lots of gas? Things like that...........
  9. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    i know how that is being a daily driver. the more problems you have the more you learn. i am in your same boat. i went from knowing very little beyond a vw bug a year ago to being pretty confident now. 2 things. 1. spend a lot of time on this site, 2. fix a lot of stuff yourself. i have gone through an engine, 2 drivelines, u joints all around, bearings, water pump, alternator, steering pump, master cylinder, drums, flex plate, yadda yadda yadda. probably nothing compared to half of the people on this site. eventually you will learn if you just try to fix it yourself. you will save a lot of money too, buy a book, use this site and you should be fine for most things. good luck.
