Blazer wont start
Discussion in 'The Garage' started by lak2004, Feb 16, 2007.
  1. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Ok so since I bought my Blazer I have had a few problems with it starting occasionally. It is getting plenty of fuel and i just did the spark plugs, I bought a new cap and rotor and plug wires but I havent had time to do them yet. It will crank and crank but not start, it wont even try to start so it seems like its not getting a good spark. What should I check after I do the cap and rotor and wires? Timing I am guessing, but is there anything else. Specs are 350 with edelbrock carb and intake manifold, in line fuel filter, just put in a new red top optima and new 100amp summit alternator. Thanks
  2. dyeager535
    26,982
    191
    Well, are you actually GETTING spark? You don't have to change any of the items you bought to check that, but it possible one of those items is the culprit if you DON'T have spark.
  3. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    Yeah, you can get a cool little test light that plugs inline with one of your plug wires. You can see it light up if there's spark. Or just use the spark to frame method. Real easy thing to check.
    Start with the easy stuff make sure fuel squirts out when you move the throttle linkage and make sure you've got spark at the plugs.
  4. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    Figured it out I think its the fuel pump so turns out I just thought there was enough fuel. Now I have to put a new brake line on :doah: . Ha funny story friend was pulling me to my house with chain i couldnt stop because of ice so i ran into the back of him and the chain looped around my axle and tore the front brake line off the drivers side caliper. OOps. Of course no damage beside that. The looks we got from people who saw were pretty damn funny :D
