Blazer wont stay running..........
Discussion in 'The Garage' started by hi pinion, Nov 17, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ok, in the morning, when my wife started up the blazer,it stayed going good for around 5 muimutes and then deid.And then after that, every time after she tried to start it, it died. /forums/images/graemlins/confused.gif But it ran real good at first. /forums/images/graemlins/confused.gifI havent went out to check it yet but i wan wondering what could this be? I havent changed the fuel filter in a while BTW. /forums/images/graemlins/thumb.gif
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    carb or FI? if a carb, probably the choke staying closed...
  3. hi pinion
    Sep 25, 2003
    5,354
    carb /forums/images/graemlins/thumb.gif
  4. hi pinion
    Sep 25, 2003
    5,354
    it was rebuilt not long ago /forums/images/graemlins/thumb.giflike 3 yrs /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You ran out of gas........
  6. hi pinion
    Sep 25, 2003
    5,354
    No i diddnt run out of gas.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    was it cold?? my blazer has a little trouble getting going in the morning when it is cold, have to up the rpm's for a few seconds /forums/images/graemlins/thumb.gif
  8. hi pinion
    Sep 25, 2003
    5,354
    like i said it was running good for 5 min. /forums/images/graemlins/thumb.gif
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    SOunds like either the fuel pump or filter. You can either replace both (not too expensive) or 1 at a time. I'd go with the filter first. Cheaper and less work
  10. hi pinion
    Sep 25, 2003
    5,354
    Thanks Bryan, thats about the best advise so far. Thanks for the positive input,jake /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  11. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] I was thinking the fuel filter or that. /forums/images/graemlins/thumb.gif
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Like I said on the phone...check in order.
    1. choke staying shut.
    2 fuel filter.
    3.Check fuel pressure pre filter.
  13. hi pinion
    Sep 25, 2003
    5,354
    /forums/images/graemlins/thumb.gif Im not as good as some of you on here, i kinda suck at this. Still after all this time. /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
