Blazer72....weld on caliper brackets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudgrip, Mar 24, 2002.
  1. mudgrip
    mudgrip Registered Member
    Nov 22, 2001
    22
    Newport, Oregon
    I searched through all the related posts and couldn't find anything about where to get the weld on brackets you used on your 14bolt ff. I would have sent a PM but you don't have an email listed. Could you please let me know where you got the brackets and what caliper you used?
    Thanks in advance
  2. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Try <a target="_blank" href=http://www.speedwaymotors.com>www.speedwaymotors.com</a> under the Race Products section. They have some nice weld on mounts for about $15 each that use standard GM calipers. I think the Caddy calipers will fit but I don't know for sure. Does anyone know if they use the same hole spacing as regular calipers??
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    there are 2 types of calipers with different spacing, the ones from the 76-78 el dorado calipers have the same spacing as the d44 calipers.
    ARQ.
