@^*%#!& Bleeder Screw !!
Discussion in 'The Garage' started by txfireman110, Jul 6, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Who knows how to get a stuck bleeder screw UNstuck (in a D60).And by the way, I broke it off so now there's only about 1/4" left sticking out/forums/images/graemlins/yikes.gif(mind out of gutter please /forums/images/graemlins/shame.gif)
    Thanks /forums/images/graemlins/bow.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    If you have a welder weld a nut to it, the heat breaks it lose and it usually spins right out atleast both mine did.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Man I had a Russells speed bleeder strip out on me, I just grabbed it with a pliers and tore the threads off and yabked the thread material out. I don't think it will work with a noce solid bleeder screw but maybe.....
  4. jrsheets
    jrsheets Registered Member
    Mar 15, 2004
    68
    Katy, Texas
    you can try vice grips, a torch and just wiggle away. If that doesn't work, i usually weld a nut to it and break it free. If you don't have a welder, then you might be buying a new caliper
  5. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    If you can cut a slot in it with a hacksaw or something, you may be able to use a screw drives.
    Also, you may be able to use an "easy-out" tool.
    Another option is to use a reverse drill bit slighly larger than the opening on the bleader. /forums/images/graemlins/peace.gif
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I have brazed a 3/8 nut over the boogered remains of many bleeders and they came right out--the trick is to let it sit for ten minites after you braze or weld the nut on,the heat soaks into the threaded portion of the bleeder and helps loosen the tapered seat up,then it usually comes out easily--having a 9/16 head to wrench on is much better than a 1/4 inch or 5/16 too--.I hate bleeder screws,and having to bleed brakes (especially alone!). /forums/images/graemlins/crazy.gifIf all fails,the calipers are 11.99 at auto zone for my truck at least,wheel cylinders are 8.99 each--so guess what I did on my 82 when he calipers wouldnt push back in and the bleeders were stuck? /forums/images/graemlins/ignore.gif
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    You're not gonna find D60 calipers for $11.99 anywhere...
    Rene
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Sorry--I didnt see the "D60" part of his post! /forums/images/graemlins/blush.gif But I did say "for my truck at least" /forums/images/graemlins/grin.gif--now I'm glad I dont have a dana 60!. /forums/images/graemlins/whistling.gif
  9. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  10. backcountry
    May 27, 2004
    916
  11. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Calipers are pretty cheap I think. They only way I have had success in getting something like that out is the welding of a nut to it.
