bleeding a powersteering pump???
Discussion in 'The Garage' started by aj_tatted, Jan 27, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    is it necessary to bleed a powersteering pump?
    and if so how do i go about doing this?
    i put a new one in as well as a steering box and it seems to have air. hmmmmmmmm /forums/images/graemlins/doah.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Take the PS belt off and spin the pump backwards. This should bleed the air from the pump.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You must jack the front wheels off the ground and then turn the wheels from left to right about 20 times and it will bleed out any air. For whatever reason the wheels do need to be off the ground.
  4. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    o.k,..next ?,....i finished my crossover steering and with that 2 wheel drive box in,...my steering is crazy easy.
    i already tried adjusting the adjustment screw on top of the box alittle (i didn't turn it much do to the fact i don't want to burn this box out) is this the only adjustment that can be made? /forums/images/graemlins/bow.gif
  5. 2_wacko
    2_wacko 1/2 ton status
    Sep 29, 2007
    210
    Texas
    With truck on or off?
  6. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    on, or else the pump wont be turning and be able to self bleed.
    As for having the wheels off the ground, I have never had to do this. I just turned the wheel full lock to full lock multiple times, occasionally checking the fluid level, until the whining stopped.
  7. sweetk30
    Nov 1, 2004
    25,551
    545
    horseheads , ny 14845
    no truck off at first.
    wheels up off ground turn few times till fluid level goes down and then top of. once it wont go down anymore then fire up and make sure it dosnt go dry. then running should be just fine left to right.
    if you get to much air in the pump and fluid it takes a long time to get it out and also can hurt the pump with air in the system.
  8. 2_wacko
    Sep 29, 2007
    210
    Texas
    OK thanks I just did a frame swap and getting everything ready to drive again.
