bleeding abs
Discussion in 'The Garage' started by bushmaster, Jun 8, 2003.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    replaced rear wheel cylinders in a 93 2500 and cant get rears to bleed not getting any pressure at bleaders truck has abs system think proportion valve maybe stuck any sugestions? thanks
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    crack the lines and let them gravity bleed.. may help... if anything, bleed the master a couple shots, then the valve... then the cylinders..
  3. Can Can
    15,555
    151
    Cochrane, Alberta, Canada
    Oh, you mean ABS as in brakes!!! /forums/images/graemlins/shocked.gif I thought you were telling us that you were bleeding from your abdomen.........
    Sorry, brother- I couldn't resist!!! /forums/images/graemlins/wink.gif
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Shouldn't be related to the ABS system, the system is in the "open" mode.
    The Prop/Combo valve prolly clicked on ya', is the Red Brake Warrning Light on ? If it is, than the combo valve shut the rear lines off.
    Try bleeding the front lines, it might reset the valve. Or you might be able to crack the line (with pressure applied) on the front-out-bound side of the valve.
    or
    There is a plunger on the side of the valve, I think you hold the plunger "out", or maybe it's, prevent the valve from moveing at all... I don't remember, it's been awhile since I've delt with those.
    Anyway, you need to reset the valve, one way or another.
  5. bushmaster
    Jun 1, 2003
    146
    ct
    yes warning light is on bled fronts hild pin in on combo valve. still nothing any othes suggestions to reset valve do they go bad?????
