bleeding brakes and brakeline question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 16, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    got some new brakelines for the front today, the part that goes from the bracket on the frame to the caliper. How do I need to put them on? Just unbolt the old ones and stick the new ones on, and then bleed the system really good? Doing an axle swap soon, so I'll do this then, and just have to bleed one time. Does this sound right? Any tips on bleeding the system? Thanks
    90K5
  2. scooby
    scooby Registered Member
    Aug 26, 2001
    62
    SURREY B.C. CANADA
    all u need to do is re the old ones and install the new ones in the same place as the old ones, u will need to bleed the whole braking system begining with the wheel furthest away from ur master cyl .including ur rear whl cyls aswell. most likel the bleed patern will be right rear, left rear, right front and then the left front .
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    also make sure you have something to catch the brake fluid when you disconnect the line from the caliper. that stuff will go everywhere
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    yeah and for safty wear glasses.
    on the front there should be there nipple type things on the wheel, above where the lines attach, loosen that, then have someone hit the brakes till the juice pops out, then tighten them
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Hey man. You have to remove a saftey clip from the rear of the bracket to get that OEM line off. Take a screw driver and tap on each side of the clip till it pops off or you can use pliers to get it off. Since you arent going to reuse the OEM lines just clamp them off with locking pliers. Remove the bolt holding the hose to the caliper. Locate your new axle and bolt it in. Connect the new line to the new axle and then go at the OEM line. Keep the cover on the fluid resivoure to keep it dripping and not gushing at you. When your ready to do the brake lines you wont have as much fluid loss and mess to deal with. Bleed from rear to front clockwise starting with the pass. side. This is what I have done and had no problems to this date.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Now would be a good time to get the old fluid out of the reservoir and refill with fresh, BEFORE starting to bleed. By the time all the air is out, the lines will have fresh fluid in them and it'll be a low-buck brake system flush.
    September 11, 2001--"A date which will live in infamy"
