Bleeding brakes on 14BFF on '83 RV
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mattman, Nov 26, 2001.
  1. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Bleeding brakes on 14BFF on \'83 RV
    Maybe some one can help/has seen this problem. My dad has an RV based on an '83 one-ton chassis with a 14BFF rear. The problem he is having (I haven't seen this myself so I'm describing as best I can) is when he is trying to bleed the brakes he is having a heck of time getting a wrench on the bleeder screw. He says the springs and the deep set drum make it real bear. I was posting here since with all the 14B's floating around maybe someone has experienced the same problem and has a creative solution.
    90 GMC Jimmy, 350 TBI, 700R4, 32's, D.O.D.
    84 Bronco II 210,000 smoking and going.........
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Bleeding brakes on 14BFF on \'83 RV
    Is he using a bleeder wrench or just an open end flare nut wrench? I've got a bleeder wrench that looks like an "L", with a socket welded on each end. Can't get much leverage with it, but it fits into tight spaces and doesn't round off the bleeder screw.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    yep I have several. of course all mine are Snap-on and they are about $30 ea.
    They work great though.
    Good thing I use them all the time.
    <font color=green> Too bad ignorance isn't painful </font color=green>
