Bleeding brakes
Discussion in 'Pacific Region' started by Muddytazz, Apr 6, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Anyone any good at bleeding brakes wanna swing by and give me a hand? I did my axle swap this last weekend and for the life of me can't get what seems to be all the air out. Or at least that is all I hope it is.
    Before the axle swap, I had perfect brakes, after the swap, I barely have any....my foot goes to the floor /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    if you ran the master dry you may have to bench bleed it again, or at least do some line crakkin at the master, and if theres no fluid at the wheels, get it movin, if there is, have someone push down as right after you open the bleeder, and then close it when the stream dies, dont i repeat DONT pump /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif why you ask, EZ, you take one huge air bubble and splatter it into 9,000,000,000 particles, then you have to bledd 10x more. /forums/images/graemlins/wink.gif
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I never ran the master dry....when I swapped the rear axle, brake lines were only disconnected for about 15 minutes and the ends of the lines were plugged with golf tees.....the fronts were only disconnected for about 10 seconds each side.
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    should a piece of cake /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif are the new cylinders puking? /forums/images/graemlins/doah.gif
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    and do you have th erear prop valve? if so, may need to bleed some air out at those lines too, and its a PITA!
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm getting steady streams out of the rear caddy calipers, the fronts on the other hand are spitting, burping, doing everything but a steady stream /forums/images/graemlins/frown.gif
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    rear prop valve?
    The only prop valve on my burb is the stock one on the front cross member /forums/images/graemlins/dunno.gif
  8. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    was yers a 1/2 ton? mine is a 3/4 so it has the rear prop valve too, right up by the gas tank f/r corner, has a arm that goes down to the axle to level out weight dispurtion better. are the rear calipers leaking behind the dust rings/forums/images/graemlins/dunno.giftry to bleed th eway i explained, sounds like excessive air that is getting exploded as i call it.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, mine WAS a 1/2ton
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    One thing you need to check close is the rear brake shoe adjustment. Get them adjusted until they drag on the drums then back off a hair. I didnt adjust mine out enough when I first did my 3/4 ton swap and had the same problem with pedal travel.
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    One thing you need to check close is the rear brake shoe adjustment. .
    [/ QUOTE ] /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
  12. kennyw
    Jun 9, 2002
    13,223
    94
    Yes, I did read that too, but he may have more than one problem and needs to be sure they are mechanically adjusted right. Take care of that problem and the fronts will bleed out better because the pedal travel will start pushing fluid thru the front rather than sending it all to the rear to make up for excessive travel...
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i was just giggling at the shoe part /forums/images/graemlins/grin.gif
  14. kennyw
    Jun 9, 2002
    13,223
    94
    What did I spell it wrong? Shoe, Sheo... no that cant be it? /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/doah.gif Nevermind...
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    He's talking about the part where I do not have rear shoes....I have rear disks /forums/images/graemlins/histerical.gif
  16. kennyw
    Jun 9, 2002
    13,223
    94
    Yep, finally figured it out /forums/images/graemlins/rotfl.gif Kinda trying to do too much at once and reading thru things quickly... /forums/images/graemlins/whistling.gif
    Gotta design the nuclear power plant Homer Simpson style you know /forums/images/graemlins/histerical.gif
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  18. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif/forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif/forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
    Bill
  19. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  20. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Did ya get em fixed?
    Worn or missing coppers will let it draw air.
    You should have had a good pedal right away.
    For what you did you should have been able to gravity bleed each caliper and give it a couple of pumps to purge the air.
