Bleeding brakes
Discussion in 'The Garage' started by 1979jimmy350, May 18, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I started to try and bleed the brakes on my project, i got the fronts to bleed but, i can not get any fluid to go to the rears. I even unhooked the hardline before the t in the line for the rear and can still not get fluid to come out the lines. Could this be caused by a bad master cylinder? Or do i just need to blled them longer?
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    well, first off you should always start with the end the farthest away from the MC. this typically means the rears first. if you are unsure, you can try bleeding the MC itself. see if that works, then make your way down the line till you find the culpirt.
  3. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Are you sure about this? I always thought you started with the end closest to the master cylinder, and then work your way to the farthest.
  4. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    no, the one farthest away. i usually start with the pass rear. then driver rear, then pass front, then finally the drivers front.
  5. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    And to think I have been doing it wrong all these years. :D
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    well, perhaps it doenst matter that much. but i have always done it that way and was showed by my father (where pretty much everything i know about automotive things comes from) that that was the "correct way".
  7. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I just went through this and four of the big bottles of brake fluid, I even went and got a new master and still the back brakes wouldn't work.
    I tried the manuel method, I tried presurizing the reservior, and I tried a vacuum method, and nothing work. I was about to go get another master thinking it was bad and as a last resort I tried the vacuum method with the pressurized reservior and that finally worked.
    After going through that mess I think It may have been that I didn't bench bleed it good enough.
  8. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I just looked at a repair manual, and "sh!t howdy" it said "Start from the farthest first". Man I just bled my brakes on my truck about three months ago the wrong way, but it they still work pretty damn good. I guess there is something to be said for reading instructions.
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You just gave every female out there ammunition man!:eek1: You better take that back right now!:D
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    to go farthest from the mc. u'd do driver rear, pass rear, pass front, driver front. thats what i always do. u probably have a ton of air in your lines, keep doing it
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Cap the master cylinder and open up one rear line. With the line open, have someone push down on the brake pedal slowly(dont let it come back up at any point while pushing down). Then when at the floor, hold it and close the bleeder. Keep repeating this until you get fluid on both back line.
    A friend of mine bleeds all his lines like this and it works good.
  12. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    I can't believe it would work that way, because you'd be putting air in the line every time you crack the bleeder. Did the pedal feel solid?
    Just bought those new spring and ball bleeders, really makes the job simple, I can't even screw this process up!!
  13. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Sometimes you will have a clogged rubber hose, or one that has a weak inner wall and it blows up like a balloon, ran into those a few times. I replace every thing, saves a lot of problems.
  14. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    My brakes feel good, but not great. I think they could be better.
    This is what I am looking into...buying a set of those Speed Bleeders. And after I buy a set of those Speed Bleeders, I will bleed my brake system again...correctly this time. :D
  15. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    I think they're about $7 a pc. I put them on the front, gotta get a set for the rear, I think you'll like them. plus my wife won't be pumping my brakes any more! I can't even count how many times she left off the pedal
  16. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    :haha: :haha: :haha:
    This is the exact same reason I need a set of speed bleeders.
