bleeding eldo calipers
Discussion in 'The Garage' started by TX Mudder, Apr 24, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    WIth the bleeder pointing down, I'll need to take them off to bleed.
    How do I keep the piston from coming out? I don't have any junk rotors or whatever. What can I wedge in there?
    Also, to push the piston in the eldo caliper back in, say for a pad change, can I just use a C-clamp or is there something special to do? Do I need to remove the parking brake lever to push it back in?
    Questions questions...
    Thanks in advance for any help - I'm ready to call all of this brake stuff done.
    -- Mike
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The piston gets returned by unhooking the ebrake lever and rotating the ebarake mount back in. You can gravity bleed the calipers by turning the caliper upside down (bleeder on top) and let the fluid do the work. Then mount your caliper and pump them tight.
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Mike,
    By rotating the ebrake mount, you mean to take a socket to the nut where the ebrake lever attaches, correct?
    I have a Haynes ElDorado repair manual and I think that is what it is showing, but I'm not sure.
    -- Mike
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Your bleeders should be on the top, not on the bottom. If you have them on the bottom you will never get all of the air out. You will need a tool to rotate the piston in, If you use a c clamp you will screw up the caliper, it screws in. Also keep the caliper level, I had to unbolt mine from the mounts and hold it on the rotor and bleed it at the same time. They do not sit completly level when mounted and you cannot get all of the air out of them.
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The only way I could get the calipers so that the parking brake levers would be in a usable position was to mount them backwards - the bleeder is almost exactly pointing straight down.
    What tool is that? If you know the name or have a link or something that would be great.
    I ended up unbolting them and gravity bleeding them like Borrego suggested. Once I thought all the air was out, I kept tapping them with a wrench and more air bubbles came out. It took awhile, but eventually no more air was getting out and just fluid.
    -- Mike
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yes, that bolt on the ebrake lever will spin freely. You can turn the piston gently with a large screw driver as well to assist it. My e-brake levers are mounted down, bleeders up but the caliper is at a 45 degree angle. Gravity bleeding has worked great but pumping them seemed like a never ending cycle. I'm still running with the e-brake disconnected so for all the convenience, I've never followed through and finished it.
