Blind in the NIGHT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Jan 24, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Dear fellow Chevy's. My 1976 K10 Chevy's interior lights do not work. I have checked all the bulbs and they are still good. The fuse is also fine. Has anyone else had this problem....? Im hoping it is not the printed circut because they are 85$ to replace! Can anyone shed some light in my cab? Im tired of using a flashlight to see how fast im going.
    Thanks in advance....
    76_cheyenne
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    start at the wires going into the circuit board for elec. and work your way back from there,,if you have power going into the board,,then it's shot,,you might be able to just forget the whole circuit board and just go to a local auto parts store or truck shop and get new wireable light's,,then just cut out the back of the dash and and screw the new ones in place. All that you would need to do is run a hot and ground from your existing wire loom.You could even make them work on the dimmer like the old ones !
    <font color=purple>ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]</font color=green>
  3. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    Mine turn off when I turn the headlights on, not sure if that's the case but I might as well let ya know.
    80' GMC Jimmy 4x4, 350-TH350-NP205
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    does yours have a seperat switch to turn them on or are you trying to turn them on with the headlight switch? if it is the headlight switch i would replace it and then give it a try they are about $12 at any parts store
    wheeling pics
  5. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    MIne are never working, im trying to turn them on with the headlights, yet the headlights work fine. maybe i'll try replacing the switch.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes put a new one in i bet it is your problem[​IMG] thats what mine was
    wheeling pics
  7. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    Does your horn work? Both my horn and interior lights went. I found that they were on the same blown fuse.
