Blinker light gone Fast
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Dec 29, 2000.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Fellas,
    I met up with "fr8train" the other night and I was driving home, he was behind me. He noticed that my blinker (turn signal) was blinking really fast. He told me and then I noticed it was too. I do remember in the past it was never that fast. It was like normal speed, like 1 blink per second or two. Now its like 2 or 3 blinks a second. I'm really baffled b/c I don't know how or why this happened. Any ideas?? He tells me that this may be harmful, but I'm not sure. Thanks.
    Boss
  2. K5-Kowboy
    K5-Kowboy Registered Member
    Aug 31, 2000
    35
    Virginia
    Hey Boss -
    Is your front blinker on the same side working?
    [​IMG]<font color=blue> K-5 Kowboy </font color=blue>[​IMG]
    Go Through It or Go Over It....Going around is NOT an option.
  3. Boss
    2,550
    Maryland
    Yeah, they're all going fast. I tried both right and left and looked at the rear and fronts. Plus, when inside the cab, the blinkers on the dash are moving at the same speed as the blinkers outside the truck. I'm stumped [​IMG]
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  4. K5-Kowboy
    Aug 31, 2000
    35
    Virginia
    That is strange if they are all working. I've had one go out and it changed the blink rate of the other one on the same side before. From an electrical standpoint...about the only thing that is common to all of them is the flasher....might try changing it for a buck and a half. As far as damage, I can't think of any damage it would do, exept possibly decrease the life of the bulb and/or flasher.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are the side markers blinking? They're part of the blinker circuit on some years.
  6. K5-Kowboy
    Aug 31, 2000
    35
    Virginia
    Good point Harry...didn't think about that - but it is a distinct possibility!
  7. Boss
    2,550
    Maryland
    Yeah, they're all blinking. I'm going to double check all of this when I'm on lunch break (about 1 hour from now) to verify all of this. I'm starting to think, maybe this started to happen when I swapped in the Grant steering wheel about 3 to 4 weeks ago. I had to wire the horn in. That is the only thing I did, wiring wise, to the steering column. The horn works great. But, I'm thinking that maybe since then, was the beginning of the fast blinkers?? That's the only thing I can think of that will cause this. But I don't think the horn has anything to do with the blinkers. Who knows. Anyways.....I'll let yall know what I see after lunch. Thanks
    Boss
  8. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Hey Boss,
    Seems to me that you just need to replace the switch (points) ... can't remember what it is called on the fuse panel. The little silver thingy. They can either cause the blinkers to run fast or slow when they go bad. If the wiring check you did doesn't show anything, you can try the blinker switch ... only a few bucks at any parts store.
    PS Ready for the snow?
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I'm having the same problem. At idle they blink fast, but when on the gas they blink normal. It's been doing it for about 4 months now....No idea?
    If it ain't a Chevy, don't raise it up!
  10. K5-Kowboy
    Aug 31, 2000
    35
    Virginia
    The little silver thingy is the flasher. Hey boss, here's an idea! Turn on your hazard lights and see if they blink at the same rate as your turn signals or if they are "normal speed". The older model blazers had 2 flashers..one for turn signals and one for hazards. If they work "normal" with the hazards on, you can pretty much bet it's the flasher for the turn signals. Don't know why I didn't think about that sooner..but there ya go.
  11. Boss
    2,550
    Maryland
    Thanks Kowboy, I'll try that after work. Yeah, I figured it may be the flasher, didn't know they go bad though. Anyways, during my lunch, turn the blinkers and yeah, all of them work and all of them move at the same speed. After work, I'll try out the Hazards. Thankyou everyone. Oh, and Happy New Year!!!![​IMG]
    Boss
  12. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
    This has happened to me before. I pulled the taillights out of the back and redid the grounds from the lights to the body and this solved the problem. The sheet metal around where it was grounded was all rusted. Bad ground! Bad ground! [​IMG]
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    On some blazers there are two flashers. One for the blinkers and one for the flashers. Turn your blinkers on and feel whick one is blinking. Then you could swope the two. Once you swap them. The blinkers should be fine and the flashers should be fast.
    Gokartergo
  14. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Kowboy, I had a K2500 with the same problem and when we hooked it to the trailer it really made the fuses and flasher hot. I just asked my dad why and he said that it was a bad ground in the rear part of the bed. It basically caused a smoked wire and blew a couple of fuses. Not fun.
