Blinker stopped Blinking.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spencerjw, Apr 29, 2002.
  1. spencerjw
    spencerjw Registered Member
    Oct 6, 2001
    75
    Highlands Ranch, CO
    Ok, so I have an 86K5 Silverado. The other day my right blinker stopped blinking. When I click over to it is stays lit and that's it. When checking around the vehicle I noticed that all my lights work and the only thing that I can see that's different is that my right front side marker turns OFF when the blinker is on. Without the blinker on it's lit like it should be. So, with that in mind I know it's not the bulb in there (I took it apart to check anyway and it seams to be fine). However, the left blinker works just fine so I know it's also not the flasher fuse.
    All lights are working correctly except for that one little side marker, and that's only when the blinker is turned on.
    Any ideas???
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Add some more blinker fluid to it. /forums/images/icons/wink.gif
  3. spencerjw
    Oct 6, 2001
    75
    Highlands Ranch, CO
    Hm, didn't see that coming from a mile away or anything. /forums/images/icons/wink.gif
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Damn---you beat me to it Wes/forums/images/icons/laugh.gif
  5. dyeager535
    26,982
    191
    Yet another cause to determine exactly what the turn indicators do when a certain fault is happening : )
    Obviously a problem on the left side, I'd start by swapping one bulb at a time across. If the side marker is "dying" though, I'd check the turn signal bulbs (under grille too?...Ouch) first. If its neither of those (or at least the rear, easy to get to one /forums/images/icons/smile.gif
    Check the other bulbs as well. Swapping them side to side one at a time has worked for me in the past, as I've had bulbs that appear good (filament appeared intact) but didn't actually work.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Change the bulbs,and flasher..
  7. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    Mine 86 just did the same thing change the flasher fuse thing under the dash in the fuse box it is the bottom right round one cost like $2 Hope that helps if that is not the solution check the bulbs
  8. spencerjw
    Oct 6, 2001
    75
    Highlands Ranch, CO
    Thanks, I'll try that. I figured that since the left worked the flasher wasn't bad, but I guess that could easily be the problem.
    thanks agian, I'll try that tomorrow.
  9. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I thought the same thing and change the flasher and it worked then .....
