Blinkers not working
Discussion in 'The Garage' started by akbound, Feb 10, 2005.
  1. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    My flashers work but my turn signals don't......do I have to replace the switch in the steering column?
    Thanks!!
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You may just need a new fuse for flasher unit. Under the dash near the fuse block, it my be in the fuse block, you'll find 2 big round units, usally with metal caseing. One controls the 4-way, the other is the turn-signals. As a quick test, you can just swap the two and see if you turn signals work then.
