blinkers not working......
Discussion in 'The Garage' started by stallion85, Dec 8, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Will the blinker relay going out allow my 4 ways to work, but not my blinkers? When I turn the headlights on both the blinkers light up inside on the dash, but do not respond to the column switch. The 4 ways work fine though.....:doah:
    What's going on?
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Yes it can. Could be several things though. I would swap that out first as cheap as they are.
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
  4. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    [[​IMG]quote=makovai][/quote]
    Napa said they were all out:dunno:
  6. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    has 2 flashers...
    The 4 ways have a separate flasher of thier own..both the flashers are in the fuse box..
    If your turn signal idicators glow when you put the headlights on, there is probably a bad ground causing a feedback,or one or more directional bulbs may have one filament broken, and its laying over onto the other filament in the bulb,that is for the parking lights..or a bad flasher can do it too..time to start checking bulbs and wires..hope its not your directional switch,that can cause this too,but they dont fail very often..
    I think you can swap the 4 way flasher for the directional one, to test if the directional one is faulty--they have the same 2 prong setup..:crazy:
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Went to the JY today and grabbed three relays. Turns out it was a relay as my blinkers work again:)
    The blinker lights still glow when the head lights are on. I will check what Diesel4me has suggested.
    I thouroughly enjoyed my trip to the yard this morning. Me, a bag full of tools, and a 100 chevy's to pillage from.......it was the best part of my week so far.
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup, Bad ground or unhooked somewhere. Had the exact same thing happen, I accidentally cut a ground wire when "cleaning" up the wiring... Ha, took me 3 hours to figure out what I had done :doah:
