Block decking???
Discussion in 'The Garage' started by Diesel Dan, Oct 17, 2005.
  1. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Any machine shop gurus out there? :D
    Here's what I'm working on. About 3 years ago put together a '96-00 L31 Vortec crate motor for a blazer repower. Was a new GM crate motor, installed the "hot cam" kit, .525/525 lift with 1.6:1 self-aligning roller rockers with duration in the 218/220 range @.050 lift. R&R heads and had the spring pockets opened up and towers turned down for seal clearance. Installed Performer RPM intake and performer 750carb. With about 9.5:1 compression and proper tune it should have been in the 400HP range.
    Now up to current speed, truck was rolled and burned.
    Redoing engine and owner wants closer to 500hp :doah: .
    So in fire carb melted, MSD billet dist, gear drive starter and all accesories toast.
    Going with Edelbrock Etech 200 heads, flow better than GM fast burns. RPM air gap intake, maybe a 1460 series holley 750 that GM uses on the 430hp/350. Also looking at the Edelbrock RPM roller cam, .560/.580 range and CompCams chromemoly 1.5 rockers.
    Now machining question.
    Looking at decking the block. All pistons measure .026-.030" below deck height. How much can a stock block reliably be decked? Don't want to, at this point, get into offset bushing the piston pins to raise them to the top of the deck.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    When I built my 388, all of the pistons were down 0.011 to 0.019". I had the block square decked so they were all down 0.004".
    Taking 0.025" off the deck of block should be ok but I would check with the machine shop. They usually know what works and what they would feel comfortable with. :D
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive heard of people using zero deck hieght and using the head gaskets for proper quench.
  4. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is basically what I did, except for the zero deck. With the piston down 0.004 and a compressed gasket thickness of 0.041", I get the ideal quench thickness of 0.045". :D
  5. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Called the machine shop and the guy that does the decking wasn't in today. IIRC distance from the crank centerline to deck height spec is 9.800 +/-??? So it will also depend if I'm above or below the mean dimension of 9.800" and if I go the whole .022" I'll need to check pushrod length.
    Now I'm trying to find out what the limits are on the powdered metal (PM) connecting rods.
