Block heater on 6.2 diesel?
Discussion in 'The Garage' started by BlazerRaiser, Nov 25, 2006.
  1. BlazerRaiser
    BlazerRaiser Newbie
    Nov 23, 2006
    Delaware
    I have recently bought a 6.2 diesel K5 and put 35" w/ a 6" lift on it. This truck ran great all summer but as soon as 40 degrees came around it seems that it doesn't even want to turn over. This is my first diesel and I don't know where the Block heater would plug in at or if it has one??? (note:) this is an old Military vehicle. Does anyone have any ideas?
  2. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    Glow plugs! Batteries!
    My M1009 wouldn't start in the California spring, which is mild by most folks' standards ... the glow plugs were shot and the batteries were weak.
    New batteries (btw, group 32P's fit, and can be had in like 1100cca or something) helped, but the new plugs were the kicker. Get the AC Delco 60G's, or the Kennedy quick heats from Ebay if you're so inclined.
    After that, think about a block heater if it's still having trouble ... but it's like putting a turbo on a car that's not had a tuneup in forever... get it back to stock first :)
    -- A
    Mattj likes this.
  3. wheels_of_steel
    wheels_of_steel Newbie
    Nov 15, 2006
    saskatoon
    I have a 6.2 diesel in my truck and it HATES winter, anything below 0 andd it has to be plugged in. You can check glow plugs by continuity to the block and the connector. My truck has a circulating block heater and its a night and day difference, it goes inline on a heater hose. Wal mart should have them.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    good tip on the inline heater in the heater hose! the stock set up was to have the block heater as part of one of the freeze plugs (mine was drivers side, but i no longer have the block heater). you shouldn't be having problems at 40 degrees tho. definitely check battery, plugs and starter for good power/heat/cranking speed.
  5. dremu
    Feb 27, 2000
    15,952
    444
    Slight hijack ... I seem to have one of those, as I was peering at my diesel today I discovered an electrical plug looking thing in a freeze plug.
    Not like I need it, but would one just hook that up to 110V AC to do its thing?
    -- A
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah - there's a cord which hooks up to the freeze plug and the other end is your regular 3 pronged electrical plug. :)
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Checking continuity isn't reliable. They often won't go open-circuit until they get a shot of current. I could only detect 2 bad plugs via continuity alone. Turned out 6 were dead. ;)
    I used an AC clamp-on meter because I had nothing else. I know - won't work for DC right? Well, it will detect the change in current right when you turn them on. I set it to catch the peak value so I didn't have to be in 2 places at once.
    IMO,a circulating heater is always better. Also good if you put it on a timer you aren't wasting power all night long.
    Starter, batteries, and glow-plugs can all be culprits when it comes to starting the 6.2L in cooler temperatures.
  8. BlazerRaiser
    BlazerRaiser Newbie
    Nov 23, 2006
    Delaware
    Thank you all for your help, I got the starter checked today it was fine and the batteries are at full charge. Plugs are next. I'll keep you all posted.
  9. Taerkaster
    Taerkaster Newbie
    Sep 19, 2011
    Renton WA
    Good electrical=great rig
    I shared similiar problems turning over in my CUCV. Im a poor college student but I still recommend buying new glow plugs and brand new batteries. Just yesterday I decided it was worth spending more than 280$ on 2 new batteries. I am running best in the industry batteries running 800 Cold cranking amps EACH and 1000 warm cranking amps each. Starting my CUCV has never been easier or faster. I would highly recommend it if you havent already. When working with a CUCV make sure all your systems are working properly before making any modifications. With my new plugs and batteries I have never been happier spending that extra money for a more reliable truck :woot: Have fun with your rig! :waytogo:
    -My battery
    2X MEGA-TRON PLUS 78 AUTOMOTIVE BATTERY 85 MONTHS 800 CCA
    Good luck!
  10. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Did the plugs fix it?
    My truck will start at pretty much any temp without being plugged in. Coldest it was I think was about -20, it didn't like it but it fired right up
