@*%#*&$ BLOCK HEATER #&%*!@$#^
Discussion in '1982-Present GM Diesel' started by joez, Dec 16, 2003.
  1. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    ive broken 2 fingers, bent 1 crowbar, broke one pair of vice grips, and this thing still hasnt moved. anybody who has replaced one have any tips? it would be nice if it was rusty, im sure it would come right out then. im about to take the dremel to it and see if cutting it into pieces would help, but im worried about the little shavings ending up in the coolant and clogging something. or drilling it and tapping it and putting a nice long bolt on it and see if that works. anybody have any tips? this is making me really /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  2. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I know the feeling. I have a very limited tool supply at my disposal. So things that are easy for people with a decent set of tools can turn into a major task for me. Lastnight I was out trying to get a bolt loose that is on the INSIDE of my van. I saturated it with WD40.. and still broke a drive extension, screwdriver and channel locks. I was out there working on that same bolt for at least 3 hours. That bolt is still there. Tight as ever /forums/images/graemlins/angryfire.gif
  3. BiggBlazer
    BiggBlazer Registered Member
    Apr 13, 2002
    18
    Manitoba Canada
    Advice from the "Great White North". Just undo the bolt ALL the way, pull the heater out, angle it as you go- the element is bigger than the hole. Then just reach in with long needle nose pliers to pull out the winged nut. /forums/images/graemlins/thumb.gif
  4. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    the bolt is all the way out. i am either going to hit it with a torch tommarow, or just cut it into 3 pieces and remove each piece individually. i wasnt too pissed until the vicegrips broke and i broke the second finger(its a real pain to type).
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Reminds me of my first girlfriend… /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    sorry, it's getting late....
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    well, i finally won. i had to drill a hole in the heater, and thread a big screw into it, and use my new unbent crowbar to pull it out. i had to drill a second hole, cause the first one ripped out. but i got it out.
  7. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,725
    11
    Washington State
    Were you concerned about cracking the engine block in trying to remove the engine block heater? Mine is at an angle where I can get a screw driver under it. I'm afarid if I really start to crow at it that the block is going to chip or break.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    :D 7 years ago :p:
  9. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    No kidding, this has to be one of the first threads I ever started.
  10. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Wow, talk about coming back from the dead...
