block huggers
Discussion in 'The Garage' started by shaun, Nov 9, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Will block hugger style headers work with our trucks (90 jimmy) or will they contact the mounts or crossmember. Anyone with experience. My longtube headers get in the way of everything. My driveline, my starter, my shift cable, and they burn my plug wires bad so I am going to swap to block huggers. I just want to know if these will work on our trucks. Anyone with experience?
  2. bonanza
    bonanza Registered Member
    Oct 18, 2004
    55
    Sterling, IL
    If you think headers are such a pain in the ass, why don't you just go back to manifolds? Even if blockhuggers will fit, any gain won't be worth the trouble. If they are burning your plug wires, you obviously have your plug wires run incorrectly. Run them over the valve covers, and use wire looms. If you still have problems, try Accell shorty header plugs, and use wire insulation.
  3. dyeager535
    26,979
    I agree.
    I've got long tube headers, and I don't have any of the issues you mention, although shackle bolt interference was a bit of a pain.
    Any decent long tube headers will clear everything.
    Spend a few extra minutes (or hours in my case) coming up with solid mounting points for your plug wires, and they will never burn.
    pics 3 and 4 show the "solid" plug wire mounting points I came up with...the heads have tapped holes that make something like that easy to rig up.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    [​IMG] Long time ago I saw this tip in a magazine. It works great and is cheap. Much better than any looms I've seen and attractive. You can also use red or yellow or several different colors of wire ties. Wrap one loosely around the outside then one between each wire, then tighten all slowly until tight. Messed up? Cut 'em off and try again, you only used twelve cents worth! /forums/images/graemlins/peace.gif
