Block to bellhousing dowel removal
Discussion in 'The Garage' started by rcamacho, Feb 2, 2007.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm going to run the dial indicator tomorrow, I suspect the block to bellhousing alignment is off and may need to install offset bushings.
    Q: how do the heck to I remove the old dowels from the block?
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    warm the block up a bit with a small propane torch. Try not to heat the pin.
