Blocked port?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by angrysnowplow, Mar 21, 2003.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    My old intake gasket had the last port on each side blocked off, and the gasket kit I bought has ones that are similar, and ones that aren't blocked...can someone tell me why the ports are blocked?
    Also a guy at the dealership suggested I put some liquid teflon on the threads of the head bolts- good idea? Or some kind of thread lock? /forums/images/graemlins/ears.gif
    BTW it's a 1990 TBI 350
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My rebuild kit came with things that you could optionally block ports with, I have no idea why you would do this. I don't see what the point in reducing air flow is.
  3. angrysnowplow
    Jan 8, 2002
    502
    MA
    I dunno either, but it apparently came from the factory like that...some kinda weird TBI thing maybe? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. BowtieGuy3
    BowtieGuy3 Guest
    Are you referring to the last intake runner? Or the smaller port located at the very rear of the head? And as for lube for intake bolts...Factory recommendations are for oil, but I find Never-seize work out wonderfully for that.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh if you mean the ports ont he head at the very back of each one(closest to the firewall) that is becuase there is nothing there. Chevy heads are reversable, you can put them on either side of the block and it won't be wrong. This The last port is for coolant flow but doesn't go through the intake.
  6. angrysnowplow
    Jan 8, 2002
    502
    MA
    It's the smaller one on the end.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah then its thje coolant flow port which isn't needed for anything.
  8. BowtieGuy3
    BowtieGuy3 Guest
    Yup, that's just a coolant passage. It's not used, hence why the gaskets block it off. If you look, the ones up front lead right into the Thermostat area, but the ones in back are useless.
  9. angrysnowplow
    Jan 8, 2002
    502
    MA
    Ok, I get it, thanks. /forums/images/graemlins/thumb.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah the only reason its really there is it cools some and if you flip the head around it will go through the thermostat housing.
  11. BowtieGuy3
    BowtieGuy3 Guest
    I find Never-seize works out wonderfully for that.
    [/ QUOTE ] The Never-Seize I woulld HIGHLY recommend if you have Alum. Heads.
  12. angrysnowplow
    Jan 8, 2002
    502
    MA
    Nope, iron heads(well I think, a magnet sticks to it /forums/images/graemlins/rotfl.gif)I just don't want anymore bolts to break off in the head /forums/images/graemlins/angryfire.gif if there is a next time.
  13. BowtieGuy3
    BowtieGuy3 Guest
    Go with the Never-Seize then, and I do believe the torque on those intake bolts is 30 Ft./Lbs. Lemme know if you need the toque sequence or anything.
  14. angrysnowplow
    Jan 8, 2002
    502
    MA
    I've got my Chilton's book, but thanks for offering. Looks like one more trip to the store...
    Appreciate the help folks /forums/images/graemlins/thumb.gif
